BlenderKit Add-on Error #85341
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#85341
Graphics card: GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.89
Broken: version: 2.91.2, branch: master, commit date: 2021-01-19 16:15, hash:
blender/blender@5be9ef4177
Addon Information
Name: BlenderKit Online Asset Library (1, 0, 32)
Author: Vilem Duha, Petr Dlouhy
When enabling add-on I keep running into a traceback error
Just open up add-ons and trying to enable blenderkit i get errors
Default startup
Added subscriber: @pauldeecee
Added subscriber: @rjg
This is likely the same issue as #84766.
Please open Blender's installation directory and double click on the
blender_debug_log.cmd
. This will start Blender in debug mode and create log files. Try to enable BlenderKit again. Once it fails to enable, close Blender. The Windows Explorer should open and show you up to two files, a debug log and the system information. Add them to your bug report by clicking on the upload button as shown in the screenshot below or via drag and drop.blender_system_info.txt
blender_debug_output.txt
Thanks for the quick response. Hope this helps!
This should already be fixed in current version, see the ticket I've originally linked. The handling of the preferences was also improved.
Please try if the current experimental daily build of Blender 2.92 works properly for you. As a workaround in the current version I would suggest to disable BlenderKit, delete the
bkit.json
as in #84766, then try activate it again.You should also deactivate or update the Modular Tree add-on. The version you are using doesn't seem to be following current best practices for add-ons, but this is unrelated to the issue in this ticket.
@pauldeecee Please provide the requested information.
