[Bug] Filmic affect to Viewport Render Animation
Closed, DuplicatePublic
Graphics card: GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40
Version: 2.91.2, branch: master, commit date: 2021-01-19 16:15, hash: rB5be9ef417703
Since I use Nishita I have to lower the filmic exposure to -2.3. This is not a problem but when rendering from viewport the viewport render comes out darkened because filmic is affecting it and it should not affect it since in viewport it does not affect it, and when you render from viewport you expect to see the same thing you are seeing in viewport. Best regards.
Put in Color Managment > Filmic exposure to -2.3 and go to View > Viewport Render Animation.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Feb 5 2021, 2:21 PM
There is a good discussion about this in T77909: 2.83lts Regression: Viewport render image ignores colormanagement, and appears to be hardcoded to use sRGB. (including exaclty where colormanagement has an effect and where not, also including the current problems)
I am always on shaky ground when it comes to colormanagement, but is your case covered there?
This appears to be the same issue.
It is the same issue, I will merge this one into that one.
