Operating system: Windows 10 Pro x64
CPU: Intel i7 8700k
RAM: 64GB DDR4-3200
Graphics card: Geforce GTX1070
Broken: 2.91.2 (Steam) & 2.92 Beta Daily Builds from 06. - 11. Feb. 2021
(what i have tested so far)
Foam generated by Mantaflow has random square chunks missing. These missing chunks randomly change position (mostly per frame, but some stay in position longer ... ~5 Frames). Denser foam seems to generate visibly more of these.
Found two similar bugreports, but not directly related to this specific issue ... maybe a grid-issue too?
Its a simple scene (flood gate simulation), fluid domain, two fluid emitters (for the different water heights), some enviromental assets (fluid affectors -> collision ... a wall, a floor, four gates and a boat ... not related to the issue besides generating foam via fluid collision) ... short overview ...
Scene:
- 3840x2160px
- 50FPS
Fluid Domain:
- Size = 3.47m x 19.9m x 1.81m
- Res. = 256
- timesteps minimum = 2
- delete in obstacle = enabled
- generate foam particles only (no splash, no bubbles)
- everything else uses default values
Cache:
- manually set destination (external USB3 HDD)
- Frames = 1 - 2000;
- Modular (resumable)
- Format Volumes = OpenVDB
- final baked cache (guide particles + foam particles + mesh) = ~160 GB
First time i noticed this issue after baking foam and mesh (Blender 2.91.2)
A few days later (today) after further working on the scene and having switched to 2.92 Daily Builds (hoping anything would change)
Top Down View (foam particles only)
I would have provided videofootage too (showing how the holes change based on current frame), but nvidia shadowplay refuses to record blender for some reason (record desktop is enabled)
Here is the original project file (before i switched to 2.92 beta), but be warned, baking this takes some time...
Kind Regards
