Surface deform modifier doesn't work in render #85566
Reference: blender/blender#85566
Graphics card: GeForce GTX 1660 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash:
0f45cab862
I'm using surface deform modifier but it doesn't work after i click render image. However, it's still ok in viewport render
Added subscriber: @quang16121994
Added subscriber: @lichtwerk
Thx for the report.
Please share an example .blend file for others to reproduce.
Added subscriber: @Mets
I am 100% sure this is not a bug because I use this modifier on a daily basis and this is just its most common pitfall: The surface deform target object has generative modifiers on it that are only enabled on the render. You'd want to make a hidden duplicate of that target object and remove any generative modifiers from it, to use that as the surface deform target.
Closing, but in the very unlikely case that I'm wrong, it can always be re-opened, and then I'll just look like a fool.
On a side note, UX of this could be improved. Eg, adding a warning to the surface deform modifier for this case would probably be trivial(maybe not, idk) and save inexperienced users a lot of headache(definitely, as I've been there).
Changed status from 'Archived' to: 'Resolved'
Hi, thank you for your help.
I've just find out that the reason is my subdivide in viewport is 1 but 2 for render mode.
That's why surface deform didn't work.
However, i think it should work even when i don't change the same number of subdivide modifier for both view port and render mode.
The surface deform modifier uses the transformation delta of each vertex of the target object to deform the modified object, so if the target object's vertex count changes, there's no way to know which new vertex corresponds to which old vertex. There's really no good way to design around this, other than better warning the user. Or you could have a button that duplicates the target object and removes generative modifiers, but that sort of functionality belongs in an addon.
Added subscriber: @jamestomk
Thanks for the tip, @Mets; not at all obvious! The new MB-Lab plugin adds several of these. I'll file a report to somehow update their documentation (yeah: as if I thoroughly read any of it!)
