UV - scaling with individuals origin is not working when vertices touch each other #85644
5 Participants
Reference: blender/blender#85644
Operating system: Darwin-19.6.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 580X OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.10.18
Broken: version: 2.92.0 Beta, branch: master, commit date: 2021-01-24 07:38, hash:
d3506c86da
Worked: 2.79
I use individual origins and I disabled sticky selection. It works when scaling faces that doesn't touch each other, but since I select faces touching vertex next to each other scaling become like median point type of scaling.
Here is a showcase in anim gif
Same for 2.83 STL, so probably all 2.8+ works the same. When I do this in 2.79 it keeps individual origin scaling behaviour. So ... is it a bug or a feature that can be disabled ... somewhere?
I tried to ask https://blender.stackexchange.com/questions/211769/uv-scaling-with-individuals-origin-is-not-working-when-vertices-touch-each-oth, but there is not a direct answer. Thank you for help.
EDIT
(if you are OK with that I can re-edit main description, I just wasn't sure if it would not be confusing)
according to chosen unwrap type (like Smart Unwrap, Follow Active, Project from View) ... doesn't scale faces as individual origins when faces shares vertex location
2.79 works (in general) the same, just noticed Smart Unwrap works even more weirdly, luckily this was fixed in 2.8x
Added subscriber: @FilipMond
Added subscriber: @filedescriptor
I can confirm this on the latest 2.92.0 Beta, branch: master, commit date: 2021-02-15 09:30, hash:
7c864388fc
.Added subscriber: @lichtwerk
For me, this is behaving the same in 2.79 (in fact, on the same UV layout, 2.79)?
T85644_279.blend
This also seems to depend on the way UVs are laid out, e.g. the default cube with the UVs from UV Smart project actually seems to work:
T85644_293.blend
@lichtwerk Hmm ... you are right ... in 2.79 I used SmartUV and unwrap with Follow Active behave the same as in 2.93, but ...
... testing 2.79 more gave me even more weird results - some faces goes together and some of them don't ... I started to think if they share edge on object matters, but they don't.
Using SmartUV in 2.93 seems to work as expected, but ...
using Follow Active in 2.93 persists as mentioned in OP ... so what is the rule for such behaviour and what is correct? I think you can understand to my confusion ... I would expect for individual origins scaling individual faces.
Thank you to bringing light into this "thing".
BTW I came to this issue via Projection from View that is not working as well ...
Added subscriber: @sidd017
I'm working on this (new developer here), but I'm not able to understand what is the intended/expected behavior here.
I was able to reproduce this locally, but enabling UV sync selection gave even more weird results.
My exact steps :
Results when (do the following, in given order) :
Thank you @sidd017 for care ... I don't want to make it more mysterious than it is, I just tried with Sync Selection enabled and I didnt end up with your result my kept connected.
But at some point of testing happened this (with middle one disconnected) ...
I wanted to repeat again with a new file, but It ends up connected ...
I experimented if active plays some role in this, but I can't confirm that. It seem s to be random from time to time.
If I would answer what are my expectations from Individual origins simply this ...
Sure I can imagine situations where it can be useful ...
but definitely not as default behaviour for something called Individual Origin.
BTW another Sync Selection weird one (for some reason two on right side scaled as connected or should I say first two couples scaled separately?) ...
Than Undo and scale it all ...
Than Deselect and select couples as previously ...
Than these tree ...
@FilipMond This task can probably be closed in my opinion for 2 reasons :
When selected faces in a UV touch each other they collectively become one island.
Added subscriber: @ideasman42
Closing, even though this could be changed to only detect islands across shared UV-edges (not vertices), this is a design change, not a bug in the current behavior.
@sidd017
@ideasman42
Thanks for possible vision ... it just doesn't solve the individual scale per face.
So if I'm understanding to it right, there is not a chance to scale UV faces at once to get this result ...
For such a simple mesh like a Cube I had to manually select and scale faces in 3 separate steps to get the result.
For Icosphere it takes 7 individual steps with manually selecting face by face ...
... and those are still elementary examples, so you can imagine real issue like for Monkey's head in projection unwrap.
The only one way that I found as workaround is to apply Edge Split modifier, scale UV and Merge by Distance back.
That doesn't seems to be an efficient way.
Any suggestion where to discuss this thing?
Thank you for your time.
@FilipMond Thanks for the bug report, it helped point out and fix a bug with UV Sync selection.
You can discuss about efficient workarounds/workflows with other users on the #support channel at blender.chat or you can post a new topic for this on devtalk.blender.org.
It would be best to not have discussions about workflow related queries here, since this place is meant for bug reports and development related tasks.
