USD Export Crash When Parent is disabled for rendering. #85729
5 Participants
Reference: blender/blender#85729
Operating system: Linux-5.4.0-65-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: AMD Radeon RX 5700 (NAVI10, DRM 3.35.0, 5.4.0-65-generic, LLVM 11.0.0) X.Org 4.6 (Core Profile) Mesa 20.2.6
Broken:
17dddc9417
When exporting render and an object parent is disabled for rendering there it crashes during USD export.
usdtest.blend
NOTE: Use Settings for Viewport will work, Alembic export works.
The source of the crash is in
AbstractHierarchyIterator::connect_loose_objects
:Added subscriber: @Jeroen-Bakker
USD Export Crash When Parent is hidden disabled for rendering.to USD Export Crash When Parent is disabled for rendering.Changed status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @SonnyCampbell_Unity
I've tested this and it happens for both USD and Alembic.
By default, USD exports with the "Visible Only" flag ticked.
By default, Alembic exports with the "Visible Only" flag unticked.
If you set "Use Settings For" to Render and "Visible Only" is ticked, it crashes both when exporting for USD and Alembic.
This revision should fix the underlying crash raised in this bug. However I have a question about what the intended outcome is when exporting usd/alembic files.
If I set "Visible Only" and "Use Settings For" to Render, my assumption is that I should only export objects that are visible in a Render. If I disable a parent object for Render, and export the scene as in my screenshot here, should the Empty object be exported in my usd file? Currently it is being exported.
Added subscriber: @dr.sybren
Nice find!
Check the documentation for
HierarchyIterator::weak_export
:/* When weak_export=true, the object will be exported only as transform, and only if is an
bool weak_export;
This means that the disabled parent will still be exported, but only as an Empty. Thus, testing this flow with Empties will hide some of the subtleties in the exporter.
Also I now see that the comment should be updated, the special handling of "holdout" collections was removed.
Ok perfect, I missed that comment. That makes a lot of sense then, I also tested this with the usd_hierarchy_export_test.blend from the unit tests which has a more complex hierarchy of enabled/disabled objects, and that was where I first noticed it.
But yeah if that is expected then this should patch solve the crash. If you'd like I could update that comment to remove the line about the holdout collection too?
Thanks for the offer, but I've already done that ;-)
This issue was referenced by
d209629806
