Transformvalues with Constrains stays Unchanged #85984
5 Participants
Reference: blender/blender#85984
Graphics card: GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-02-25 05:34, hash:
0e1c6a29cb
Objects that have a contraint on other objects are not updated in the transform channel.
Two Cubes
Cube1 rotation-constrain to Cube2 local/global-space (no difference)
select Cube1 pin the TransformPanel
move Cube2 in Z
no Rotation-Values updating
This is also in 2.83,12 update_transformchannel.blend
Added subscriber: @walt-3
Added subscriber: @filedescriptor
I don't think this is a bug. The rotation values are constrained, but not applied to the object. If you toggle the visibility of the constraint, you'll see that the cube has a rotation of 0,0,0.
hmm!,
only for understanding,
what is the logic behind it,
not to display a value when it changes?!
If the value is not updated and I have for example a third cube(cube3) that is related to the one that has a constraint(cube2) it will be rotated even though it is at zero value if it has for example a rotationconstraint.
update_transformchannel02.blend
I as a "user" have only seen that the value does not change!
and now had no idea how I can determine this value,
That it works in the Driversetup, you do not expect.
Okay! Next time already : )
So it is rather a suggestion for improvement ?
Added subscriber: @TodorNikolov
I have also found this confusing in the past.
I understand the logic that their true unconstrained value is displayed.
Yet the "constrained values" can be used in Drivers and such. It would be nice to have an easy way to know these values.
Added subscriber: @lichtwerk
I'd say this is working by design atm.
I am a bit unsure how to classify though, leaning towards calling this as working as intended.
One possible solution (and this is clearly outside the scope of this bug tracker) might be to display
constrained
values in a fashion similar todriven
(purple) values oranimated
(green) values with their own color.But: as I said this will not be considered a bug, will quickly try to gather feedback from the animation module regarding this.
Havent had an answer yet, but if this happens, will drop a note here.
That being said, will have to close since this is not a bug
Added subscriber: @dr.sybren
Yup, this is working as intended. What is shown in the UI is the input for the constraint system, and not the output.
Just an idea: since it might be tricky UI-wise to display evaluated transforms and have access to the original values at the same time in the same UI, it might make sense to provide evaluated values in the new spreadsheet editor at some point.
(the spreadsheet edtor also displays evaluated vertex positions after modifiers for example)
@dr.sybren noted that he has an Addon for this (providing a UI to display the evaluated decomposed [into loc/rot/scale] object matrix):
https://github.com/sybrenstuvel/random-blender-addons/blob/main/transform_helper.py
(just know that is a community add-on without any guarantees or official support though)
