Grease Pencil soft edge stroke glitch in some view angles #86048
Reference: blender/blender#86048
Graphics card: GeForce GTX 660/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
When a grease pencil stroke / brush is soft or has transparency (object A) and put against another grease pencil object (object B). At certain viewing angles, object B becomes invisible around the edges of object A.
This happens in all three render engines, in viewport and renders, in version 2.91 and 2.92.
grease pencil soft edge bug.blend
{F9846388, size=full}
{F9846393, size=full}
Added subscriber: @MumuMundo
Added subscriber: @antoniov
Could you try to move your cloud object a little to front. It looks in some angles the position of the objects makes teh drawing engine not able to decide the right z-depth. If I do that in my system, the problem is solved.
Tip: If for any artist reason, you cannot move the objects, then move only the origin of the cloud object.
Thank you very much. That seemed to fix it but when I played with it more it happened again as in this updated file :
grease pencil soft edge bug 1.2.blend
{F9847338,size=full}
In another case even putting the tree far from the houses produced the same result, but changing the origin of the houses to their geometry seemed to fix it :
File with problem :
grease pencil bug 2.blend
Fixed :
grease pencil bug 2 fixed.blend
If the tree is close to the houses, fixing the houses origin and moving the tree origin far away seems to fix most of the glitches, but not all :
grease pencil bug 2.2.blend
{F9847283,size=full}
{F9847288,size=full}
Another example of the unwanted behaviour, even after I set origin points of the tree and the plane far apart.
{F9862738,size=full}
Added subscriber: @lichtwerk
Looking at this again (sorry this took so long to answer)
This is still the same problem:
For reference, this is the problem we are talking about https://docs.blender.org/manual/en/dev/render/eevee/materials/settings.html#sorting-problem [with the exception that grease pencil does not have a hashed Alpha mode, right @antoniov
So in the end, this is a limitation, but will not be considered a bug (@antoniov : please correct me if I am wrong)
@lichtwerk You are totally right. Maybe in the future with new Eevee materials for GPencil this will be solved.
