Point Instance : always generate an object eg. Suzanne very very large by default why? #86064
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
2 Participants
Reference: blender/blender-manual#86064
Pagename:
modeling/geometry_nodes/point/point_instance
Blender Version:
2.92
Documentation Language:
en
Permanent link
Hi .. I am new to geometry node usage.
I download latest version of 2.92
When every I create a new geometry node .. with simple point distribute and point instance, and target any object eg. mesh Suzanne
The object generated is very large ?!!
I try to make the object (mesh) very very small .. and try again and still object very large.
Try redo a few times with new plan and assign geometry node and define again this 2 nodes to it.
Still output is always very large . why??
How to fix this ?
Added subscriber: @seemon2
Added subscriber: @Blendify
For help using Blender, please try one of the community websites: https://www.blender.org/community/
If you think you found a bug, please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, and a .blend file with exact steps to reproduce the problem.
