Setting curves to another spline type makes them shorter #86086
8 Participants
Reference: blender/blender#86086
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.79
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
I discussed this with Campbell during a meeting 2021-02-23. He suggested that I report it as a bug.
When setting curve spline type from nurbs to bezier, the curve becomes shorter. It also becomes shorter when I convert itfrom bezier to nurbs.
It is worth to note that when converting from bezier to nurbs, the curve can get back the length by changing the following settings in
object data properties > active spline
Screen grab of issue
convert curve spline makes it shorter.mp4
Change spline type from Bezier to Nurbs - observe that the curve becomes shorter
Added subscriber: @DanielBystedt
Added subscriber: @filedescriptor
Can confirm this on the 2.92 release and the latest 2.93.0 Alpha, branch: master, commit date: 2021-03-01 06:12, hash:
bfc70a6a95
.Added subscriber: @mont29
Would consider that a known issue rather than a bug, this is just the conversion 'algorithm' being dumb and super-basic, instead of trying to be smart...
Note that you will always lose some data during such conversion anyway, since interpolation methods are quiet different.
Added subscriber: @ideasman42
Setting as paper-cut since this should be straightforward.
The desirable behavior is to keep the same number of knots (control points) for each curve type instead of treating the handles of a bezier curve as knots.
Added subscriber: @KiloCharlieAlpha
Hi, new dev here. May I have a go at this? Also, any deadlines to complete this?
Hi @KiloCharlieAlpha, the curve code is in a bit of a state of flux currently with the work on curves in geometry nodes for 3.0.
We have introduced a new data structure with support for attributes, clearer code, and better performance.
In geometry nodes there is a "Set Spline Type" node with an implementation the 6 type conversions.
If you're interested, you could look at changing the behavior in the node. Then as we transition edit mode curves to use
that data structure (still a loose plan at this point), we would get the improvements there too.
That said, I'm not sure I'd call this behavior a bug-- there are two possible goals here, keep the shape of the input curve, and keep the length.
AFAIK, the "dumb" algorithm that shortens the curve also keeps the shape quite nicely. Still worth some investigation though!
I tried converting a simple Bezier with 2 BezTriples to NURBS. It doesnt generate any knots because the curve is invalid:
I have only worked with Beziers and B-splines, not NURBS, and even the Beziers I work with are 4 ctrl pts per segment, so these triples are confusing to me as well.
Removed subscriber: @KiloCharlieAlpha
Added subscriber: @ksar
Hi, I think maybe I can have a try.
I'm removing the "Good First Issue' tag from this one since I'm not convinced it's actually a bug (as in, the current algorithm is working as expected, it's not some easy mistake to fix). The conversions can be improved, but I would like that to be done for the set spline type node, since the edit mode code will be replaced with that version at some point.
Yes, since the interpolation methods are different, different performances are expected. However, should the backward conversion keep a consistent shape?
Added subscriber: @pmakal
@HooglyBoogly if you have a minute please take a look at: D13546
