EEVEE Subsurface Node give blurry edges #86097
Closed
opened 2021-02-28 18:15:59 +01:00 by Paul Szajner · 7 comments
Operating system: Linux-4.19.0-13-amd64-x86_64-with-glibc2.28 64 Bits
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 418.152.00
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-02-27 23:51, hash: f3d60c68ef
Worked: 2.91
When using subsurface nodes on different materials edges of geometry get blurred, this doesn't append when using the principled node.
Open the attached .blend, it contains 4 cubes , two uses the principled node and render correct, the other two uses the subsurface node with same parameters.
sss_node.blend
Here is a screenshot of the file :
**System Information** Operating system: Linux-4.19.0-13-amd64-x86_64-with-glibc2.28 64 Bits Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 418.152.00 **Blender Version** Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-02-27 23:51, hash: `f3d60c68ef` Worked: 2.91 **Short description of error** When using subsurface nodes on different materials edges of geometry get blurred, this doesn't append when using the principled node. **Exact steps for others to reproduce the error** Open the attached .blend, it contains 4 cubes , two uses the principled node and render correct, the other two uses the subsurface node with same parameters. [sss_node.blend](https://archive.blender.org/developer/F9852874/sss_node.blend) Here is a screenshot of the file : ![image.png](https://archive.blender.org/developer/F9852877/image.png)
Author
Added subscriber: @sozap
Member
Added subscriber: @filedescriptor
Member
Member
I can confirm this. On first look, this seems to be a regression.
2.91.2:
2.93.0 Alpha, branch: master, commit date: 2021-03-02 07:40, hash: c4ef90f5a0:
I can confirm this. On first look, this seems to be a regression. 2.91.2: ![2.91.png](https://archive.blender.org/developer/F9859639/2.91.png) 2.93.0 Alpha, branch: master, commit date: 2021-03-02 07:40, hash: `c4ef90f5a0`: ![2.93.png](https://archive.blender.org/developer/F9859642/2.93.png)
Added subscriber: @ktdfly
This issue was referenced by d67223ca29
This issue was referenced by d67223ca297ceef4e790bf5504f38fea03941e79
Clément Foucault self-assigned this 2021-05-19 12:32:19 +02:00
Thomas Dinges added this to the 2.93 LTS milestone 2023-02-07 18:46:30 +01:00
5 Participants
Reference: blender/blender#86097
