Cycles: AttributeNode: Unexpected result when setting a nonexistent attribute #86121
5 Participants
Reference: blender/blender#86121
Operating system: MacOs BigSur 11.2.1
Graphics card: Radeon Pro 570X 4 GB
Broken: 2.92.0 release (2021-02-24 16:25)
Worked: 2.91.2
At least on MacOS, in an Attribute Node, when a non-existent attribute (previous vertex group) is set, last used color in scene is used, even being of a completely unrelated object.
AttributeNode "leaks" data from one object to another. Not only color, but alpha value (exist/not exist) too
Look at video for better understanding, see attached example blend
Screen Recording 2021-03-01 at 13.29.30.mov
Look at objects - they will BOTH have colors from the one, not from the object itself
AttriubuteNodeBug.blend
Added subscriber: @IPv6
Problem exist in 2.93 too (current latest alpha) - but leaking happens only from green to red, see screenshots
With this bug half of my nodes simply produce trash for now :(
AttributeNode completely brokento Cycles+OSL: AttributeNode brokenAdded subscriber: @mano-wii
In my case, objects without the attribute are black.
I think this is the expected result (what is the color of a non-existent vertex color).
The strange thing about your image is that it appears green.
(I'm not sure what this report has to do with OSL. The Attribute node is not from OSL).
Regarding black - yes, this is totally expected! This is how it worked in 2.91 (and all the previous versions)
In my case non-existent vertex group "produce" (from material nodes view point) last used color in scene on completely unrelated object. When red is attached and green is non-existent -> it became red also, same with green vertex group. Reproducable in 100% of cases on my mac (and many nodes from my materials are not working because of this) :(
This happens not only with color - but with "Alpha" socket too! It also leaks 1.0 even when vertex group not exist on current object - this is 100% bug, since non-existent attribute should produce alpha == 0.0 according to the docs of the feature. I can record video demonstrating this if needed
i mentioned OSL because i use Cycles+OSL combination and this blend is configured to use this combination.
May be this is not important, but i already had some rough cases when OSL caches/optimizes something hardly internaly... and force user (me) to add intermediate nodes to "uncache" this "optimized" stuff. Such "color leak to non-existent attribute" can be produced by similar caching logic (just a guess)
Cycles+OSL: AttributeNode brokento Cycles: AttributeNode: Unexpected result when setting a nonexistent attributeSome notes: seems a bug in MacOs-related. It is not present on Windows (just tested)
Added subscribers: @kevindietrich, @brecht
@kevindietrich on Linux I can confirm some kind of refresh issue, where some tiles in viewport are not using the new attribute immediately when switching between the attributes.
Can you check this? I imagine it's some missing update after the recent optimizations.
I cannot reproduce in master (release or debug build), and I am having trouble compiling 2.92 because of the libraries change (is there a branch in SVN I can access still with the right libraries?).
Running
make update
in theblender-v2.92-release
branch should checkout the right libraries.But I confirmed this in master. I'm seeing some Asan warnings, will quickly check if I see the issue.
This issue was referenced by
be51d671b5
