Color Management View Transforms no longer reflected in the Compositor Backdrop #86219
Closed
opened 2021-03-03 02:03:03 +01:00 by Harley Denham · 15 comments
Operating system: Windows 10 20H2
Graphics card: Nvidia RTX 2080 Ti
Broken: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: 02948a2cab, type: Release
Worked: 2.91.X
Color Management View Transforms / Look settings are not reflected in the compositor backdrop, preventing working visualisation of output.
Render any image.
Display "Render Result" in Image Editor alongside Compositor with the Backdrop enabled.
Apply/change the View Transform + Look in the Color Management panel to see discrepancy.
**System Information** Operating system: Windows 10 20H2 Graphics card: Nvidia RTX 2080 Ti **Blender Version** Broken: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: 02948a2cab44, type: Release Worked: 2.91.X **Short description of error** Color Management View Transforms / Look settings are not reflected in the compositor backdrop, preventing working visualisation of output. **Exact steps for others to reproduce the error** Render any image. Display "Render Result" in Image Editor alongside Compositor with the Backdrop enabled. Apply/change the View Transform + Look in the Color Management panel to see discrepancy.
Author
Added subscriber: @qxoko
Added subscriber: @sebastian_k
I cannot confirm that, it works here, both in 2.93 and in 2.92. Can you post a blendfile where it happens?
Author
I've created a brand new file with 2.92.0-release and attached it, with a screenshot to demonstrate as well.
I've backed up and checked several scenes in a commercial project created in 2.90/2.91 and all scenes are affected in 2.92 as well. At least for me, it is not a one-off issue.
T86219_color_bug.blend
I've created a brand new file with 2.92.0-release and attached it, with a screenshot to demonstrate as well. I've backed up and checked several scenes in a commercial project created in 2.90/2.91 and all scenes are affected in 2.92 as well. At least for me, it is not a one-off issue. ![T86219_color_bug.png](https://archive.blender.org/developer/F9862740/T86219_color_bug.png) [T86219_color_bug.blend](https://archive.blender.org/developer/F9862737/T86219_color_bug.blend)
Added subscriber: @Jeroen-Bakker
This is interesting. I can indeed reproduce that behavior with your file. However, if you go to a different workspace and create a compositor there, the backdrop reacts to color management just fine. Your compositing workspace seems to be broken somehow, but I have no idea how. Maybe @Jeroen-Bakker has an idea?
Author
Huh.
(I actually did attempt it in a reset-to-default copy of 2.92 and it still occurred, but I now realise I was only trying existing files with that workspace inside).
Also It seems for my installation, loading a new Compositor preset from the Add Workspace menu (see screenshot) carries this behaviour for me — it's not just the original Compositor that's open by default, the actual presets embedded in the startup file are "corrupted" too.
If I just go to any other workspace type and manually switch a zone to a Compositor as Sebastian suggests, those display correctly.
I've attached my startup file in case it helps track down the issue. I want to say it was created in 2.81 or 2.82 when I made the leap from 2.7x and has been carried over updates ever since. I do also wonder if a file created fresh in 2.8x and immediately re-opened in 2.92 might exhibit this behaviour?
T86219_startup.blend
Huh. (I actually did attempt it in a reset-to-default copy of 2.92 and it still occurred, but I now realise I was only trying existing files with that workspace inside). Also It seems for my installation, loading a new Compositor preset from the Add Workspace menu (see screenshot) carries this behaviour for me — it's not just the original Compositor that's open by default, the actual presets embedded in the startup file are "corrupted" too. If I just go to any other workspace type and manually switch a zone to a Compositor as Sebastian suggests, those display correctly. I've attached my startup file in case it helps track down the issue. I want to say it was created in 2.81 or 2.82 when I made the leap from 2.7x and has been carried over updates ever since. I do also wonder if a file created fresh in 2.8x and immediately re-opened in 2.92 might exhibit this behaviour? ![image.png](https://archive.blender.org/developer/F9863525/image.png) [T86219_startup.blend](https://archive.blender.org/developer/F9863553/T86219_startup.blend)
Author
Update for @sebastian_k — It seemed to still be occurring randomly in scenes created with my new startup file, but I've found the culprit.
Auto-Offset in the View menu.
I have it disabled by default in my old startup file and I forgot to do that with the new one. The colour profile is dropped instantly as the checkbox is changed and comes back if re-enabled. In my in my original startup file, Auto-Offset was always disabled in the default Compositor. I've also confirmed the behaviour it in the production scenes I was working on when I originally logged the bug, as well as some previously completed shots I have not opened with 2.92 until now.
Update for @sebastian_k — It seemed to still be occurring randomly in scenes created with my new startup file, but I've found the culprit. **Auto-Offset in the View menu.** I have it disabled by default in my old startup file and I forgot to do that with the new one. The colour profile is dropped instantly as the checkbox is changed and comes back if re-enabled. In my in my original startup file, Auto-Offset was always disabled in the default Compositor. I've also confirmed the behaviour it in the production scenes I was working on when I originally logged the bug, as well as some previously completed shots I have not opened with 2.92 until now.
Member
Member
Added subscriber: @lichtwerk
Member
Philipp Oeser self-assigned this 2021-03-17 16:33:10 +01:00
Member
Nice find, can confirm, will check.
This issue was referenced by aeff59073b
This issue was referenced by aeff59073b23d50a39eb0a614d3907ac0d04994a
Member
Reference: blender/blender#86219
