Rendered video is missing frames that are on the playback timeline #86361
Reference: blender/blender#86361
Operating system: Archlinux
Graphics card: Intel HD Graphics 620
Broken:
2.92.0
and also tested latest daily buildblender-2.93.0-8618c4159c7b-linux64
Worked: unknown
The resulting rendered video is lacking last frames (in fact, judging by the timeline it lacks last 2 seconds of the video). If you play the video inside timeline, you can see last frames are where there's a hand appears and the man disappears. However after I render it to a file, and play the file, the video stops some moments earlier, i.e. frames where the man is still in frame.
Also relevant is that when "rendering" is happening, you can see slider is moving on the timeline, and it shows the wrong frames. IOW, at the end of the timeline it should show a frame with no man — however instead it shows a frame with the man.
From my experimentation it seems that the problem is somehow related to cuts in the video. Because when there's no cuts or only a cut at the end, video is rendered properly.
I haven't figured a way to do this from scratch on an irrelevant video, so I attached an archive with a tiktok video I'm editing and a
bug-report.blend
file which has all the necessary setup (most importantly, cuts, because they seem to trigger the problem)./tmp
directorybug-report.blend
in BlenderRender → Render Animation
and wait for it to finish./tmp/0001-0156.mkv
file in any video editor, and scroll to the final frame of the video.Expected
The final frame is matching the timeline inside Blender, where there is no one in the frame.
Actual
It finishes with the man in frame.
bug-report.tar.zst
Added subscriber: @Hi-Angel
#98265 was marked as duplicate of this issue
#86971 was marked as duplicate of this issue
Added subscriber: @iss
Can confirm issues here,
This will probably be similar seek bug as #86971, but since there is a lot of different video formats will keep this open so I can investigate both files separately.
Again setting to high prio only because I am looking at this area currently.
Problem may be much more complicated and I may lower priority in such case.
Added subscriber: @davidmcsween
I might add here that Blender has always been challenged by difficult to decompress CODECs. Especially variable bit rate ones. IIRC some screen recorders have variable IP and B frames too. This obviously makes scrubbing/seeking a nightmare.
Added subscribers: @SyllabusGames, @mano-wii
Problem in this file is variable frame rate, which is not supported currently.
Video has 210 frames, but Blender sees only 196. When video is played frame by frame, like during rendering, decoding takes different route than when file is seeked, when it is cut or frames are dropped.
Even if I was able to resolve issue with missing frames, there will be still problem when decoding needs to seek even for one frame, it would result in big jump that is undesirable, because time in video doesn't "flow" at the same rate as sequencer timeline time.
This is not trivial problem to resolve and I am not sure if I will have time to resolve this anytime soon so I will change this form bug to known issue.
There are 2 possible workarounds:
@davidmcsween yes there are many challenges, though variable I-frame rate should cause no problem even with current implementation.
Thank you for the research!
Do you think it would make sense to solve this task by simply refusing to render the video in such situation? I imagine a pop-up message saying something like
I imagine it would help a lot to people, because otherwise they would spend hours and hours of their time trying to make it work*(as it happened to me)* without knowing there is a problem.
This is good question. I am not sure whether it is easy to tell if framerate is variable just from metadata, but will check this.
It may be possible that some devices may record with slight time deviation due to various reasons and these would be evaluated as variable framerate, but they would actually decode properly otherwise. Then it may be probably easier to actually fix playback in such files.
Added subscribers: @Deckelmouk, @OmarEmaraDev
This issue was referenced by
f0a3d2beb2
This issue has been resolved by
f0a3d2beb2
, so will close the report.
