uv.select operator is hardcoded to cycle #86382
Reference: blender/blender#86382
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40
Broken: version: 2.92.0, branch: master (modified), commit date: 2021-02-24 16:25, hash:
02948a2cab
When using uv.select operator in "Extend" mode, the selection cycles between selection and deselection instead of always extending the existing selection, and operator has no option to turn this behavior off. This is inconsistent with rest of selection operators in other Blender editors.
Result: The UV mesh element is deselected despite the uv.select operator being set to "Extend"
Expected: The UV mesh element is not deselected when an operation to Extend current selection is performed
Added subscriber: @Rawalanche
Added subscriber: @lichtwerk
Notes:
Deselect
andToggle selection
optionsThere is already a comment in
uv_mouse_select_multi
about this:This sounds like it is working as intended (but this also sounds like this could see improvements -- e.g. by exposing
Toggle selection
option and using it)I am not sure about this. This may be working as expected for a programmer who is aware of a comment somewhere in the C code, but definitely not for the user. The experienced user sees "Extend" setting in the keymap, with no implication it also means cycling. And beginner/intermediate user is probably not even editing the keymaps themselves, so they will most likely be confused about why are they deselecting elements when holding shift key, which usually means "Add to selection" in all the other parts of Blender. It's really weird if it's allowed to pass behavior which is inconsistent with most other editors for no obvious reason as intended.
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
OK, will leave that up to the module to classify/decide.
Not sure about this though, the behavior of {key Shift Click} to actually toggle seem quite common to me [sure, this then uses its own option which is not called
Extend
, true ...]?Yes, you are probably right. I have not tested with the default keymap, only with the customized one, so I assume toggle is on in the stock one by default. Anyway, I still think that if the Toggle option is available in other editors, it should be available in the UV one too. Especially given how similar 3D view mesh element and UV editor mesh element selection is, it'd be really odd to have two different workflows per editor, if user doesn't want Extend mode to also toggle.
Added subscriber: @ideasman42
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
As of
d356edf420
this is no longer the case.
