Opening Blender file with relative path breaks internal relative paths. #86544
Closed
opened 2021-03-13 10:47:24 +01:00 by Peter Baintner · 16 comments
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: 02948a2cab
Opening a Blender file from another folder with a relative path changes the relative paths to libraries so that there are too many "../" in the paths.
Opening without a relative path (how should look like): Opening with a relative path:
For easy recreation of the issue, I uploaded a zip file with a folder structure, an example file and a bat file to execute the .blend file with a relative path.
To start the test:
  • Extract the zip file
  • Edit the execute/launch_test.bat file to point to your blender.exe directory
  • launch execute/launch_test.bat
rel_path_test.zip
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30 **Blender Version** Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: `02948a2cab` Worked: (newest version of Blender that worked as expected) **Short description of error** Opening a Blender file from another folder with a relative path changes the relative paths to libraries so that there are too many "../" in the paths. |Opening without a relative path (how should look like):|Opening with a relative path: | -- | -- | |![paths_before.jpg](https://archive.blender.org/developer/F9892786/paths_before.jpg)|![paths_after.jpg](https://archive.blender.org/developer/F9892789/paths_after.jpg) **Exact steps for others to reproduce the error** For easy recreation of the issue, I uploaded a zip file with a folder structure, an example file and a bat file to execute the .blend file with a relative path. To start the test: - Extract the zip file - Edit the `execute/launch_test.bat` file to point to your `blender.exe` directory - launch execute/launch_test.bat [rel_path_test.zip](https://archive.blender.org/developer/F9888789/rel_path_test.zip)
Author
Added subscriber: @PeterBaintner
Member
Added subscriber: @lichtwerk
Member
Cannot reproduce
Operating system: Linux-5.10.19-200.fc33.x86_64-x86_64-with-glibc2.32 64 Bits
Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 455.45.01
version: 2.93.0 Alpha, branch: master, commit date: 2021-03-15 12:31, hash: `rBab6e67767e73`, also checked 2.92 release
Cannot reproduce ``` **System Information** Operating system: Linux-5.10.19-200.fc33.x86_64-x86_64-with-glibc2.32 64 Bits Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 455.45.01 version: 2.93.0 Alpha, branch: master, commit date: 2021-03-15 12:31, hash: `rBab6e67767e73`, also checked 2.92 release ```
Added subscriber: @mano-wii
I can confirm.
Apparently the problem only happens on Windows.
I can confirm. Apparently the problem only happens on Windows.
Added subscriber: @rotoglup
Member
Added subscriber: @Mets
Member
This has been coming up during Sprite Fright a number of times, and am requesting bumping prio on this.
Animators would report files breaking after using Save As to save the file somewhere else, then reloading the file. The paths end up looking like this:
And after File->External Data->Find Missing Files, aka the correct paths, should be this:
So for our case it's actually a case of not enough "../", unlike in the report, but I can only assume it's the same issue.
I've had this reported by an animator in the past who was not working on Windows at the time, so I think it might not be windows-specific, but I certainly cannot reproduce on my Linux machine. I can test later on Windows too though, with the attached .bat file.
This has been coming up during Sprite Fright a number of times, and am requesting bumping prio on this. Animators would report files breaking after using Save As to save the file somewhere else, then reloading the file. The paths end up looking like this: ![image.png](https://archive.blender.org/developer/F10164357/image.png) And after File->External Data->Find Missing Files, aka the correct paths, should be this: ![image.png](https://archive.blender.org/developer/F10164355/image.png) So for our case it's actually a case of not enough "../", unlike in the report, but I can only assume it's the same issue. I've had this reported by an animator in the past who was not working on Windows at the time, so I think it might not be windows-specific, but I certainly cannot reproduce on my Linux machine. I can test later on Windows too though, with the attached .bat file.
Added subscriber: @Rikstopher
This comment was removed by @Rikstopher
*This comment was removed by @Rikstopher*
Added subscriber: @fsiddi
Added subscriber: @mont29
@Mets this has nothing really to do with current report, which is a problem at opening a blend file with relative path from command line essentially...
Will fix that one, please make proper report for the issue that is 'super urgent'...
@Mets this has nothing really to do with current report, which is a problem at *opening* a blend file with relative path from command line essentially... Will fix that one, please make proper report for the issue that is 'super urgent'...
This issue was referenced by fbd889ec28
This issue was referenced by fbd889ec285a55872a274d72fdd0caba0a163cf7
Bastien Montagne self-assigned this 2021-06-10 18:41:20 +02:00
9 Participants
Reference: blender/blender#86544
