Boolean union causing crash when combined with a dependency loop (2.93 regression) #86879
5 Participants
Reference: blender/blender#86879
System Information:
Operating system: Linux-5.10.0-4-amd64-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.67
Blender Version:
Broken: 2.93.0 Alpha, branch: master, commit date: 2021-03-24 01:38, hash:
3f47df577d
Worked: 2.92 release (Technically it doesn't work in 2.92, but Blender doesn't crash when doing this which is why I've listed it as "worked")
Short description of error:
I've found that when the boolean union modifier is used on an object with the target object also having a boolean modifier that has this object as it's target, Blender will crash (in some situations). Here's my crash log:
blender.crash.txt
Technically this is a dependency loop and as such a user shouldn't be doing this, but I've found that from time to time I can accidentally select the wrong object with the eye dropper and as such this crash can occur.
Exact steps for others to reproduce the error:
Watch the video or read the steps below.
Difference
mode and with the duplicate cube as the target.Union
mode with the original cube as the target. Blender will crash.Note: In step 2 I tell you to select the original cube then add the
Difference
boolean modifier to it. If you instead give the difference modifier to the duplicated cube, Blender will not crash unless you change a setting on the duplicate cubes modifier after setting up the union modifier. Not sure why.Boolean union crash.mp4
EDIT:
Added a test file.
boolean_crash.blend
Added subscriber: @Alaska
Added subscriber: @filedescriptor
I can reproduce this crash on the latest 2.93.0 Alpha, branch: master, commit date: 2021-03-24 08:34, hash:
865025c343
.Added subscriber: @HooglyBoogly
Ran this through a debug build. The crash happens in
blender/source/blender/modifiers/intern/MOD_boolean.c:663
becausemesh_operand
isNULL
.@HooglyBoogly Does this just need a
NULL
check?The dependency graph detects the cycle correctly:
Honestly I'm not sure, I didn't work on this code really. If a NULL check fixes this problem it looks like it would be reasonable to add.
Added subscriber: @howardt
@HooglyBoogly I am sorry! I meant to tag @howardt !
This issue was referenced by
94079ffc7f
Yes, a NULL check was all that was needed (and also in the similar Collection case). Thanks for the report. Fixed.
