Return hover shortcuts for mesh modifiers #87012
Closed
opened 2021-03-29 14:15:46 +02:00 by Hans Goudey · 16 comments
Member
At a UI meeting quite a while ago we decided to relax the idea that the shortcuts would only apply to the active item.
So this task just involves reverting some of the early changes to the modifier operators.
This is based on feedback (https://devtalk.blender.org/t/ctrl-a-for-applying-modifier-under-cursor-2-91-not-active-2-92-2-93/17490/14)
and the noticeably slower workflow for adding and duplicating modifiers.
Also, other modifier stacks (constraints, grease pencil, effects) still use the hover shortcuts as well.
Separately, I'd like to experiment with making the modifier icon blue instead of an outline around the box to indicate the active modifier.
We didn't really discuss this, but I think it would probably look better, and since the active modifier would be less important in this scenario (only controls context), it might make more sense too.
{F9914665 size=full}
Initial feedback is that this isn't consistent with other areas in Blender (we don't use this blue icon for active idea)
At a UI meeting quite a while ago we decided to relax the idea that the shortcuts would only apply to the active item. So this task just involves reverting some of the early changes to the modifier operators. This is based on feedback (https://devtalk.blender.org/t/ctrl-a-for-applying-modifier-under-cursor-2-91-not-active-2-92-2-93/17490/14) and the noticeably slower workflow for adding and duplicating modifiers. Also, other modifier stacks (constraints, grease pencil, effects) still use the hover shortcuts as well. --- Separately, I'd like to experiment with making the modifier icon blue instead of an outline around the box to indicate the active modifier. We didn't really discuss this, but I think it would probably look better, and since the active modifier would be less important in this scenario (only controls context), it might make more sense too. {[F9914665](https://archive.blender.org/developer/F9914665/image.png) size=full} *Initial feedback is that this isn't consistent with other areas in Blender (we don't use this blue icon for active idea)*
Author
Member
Author
Member
Hans Goudey self-assigned this 2021-03-30 14:47:26 +02:00
This issue was referenced by 9f323e9bf7
This issue was referenced by 9f323e9bf79fbf4157a1426fa83dde0c04747a5b
Added subscriber: @hadrien
Having shortcuts affect not what seems to be selected is indeed confusing. This is not how the rest of Blender works : viewport, sequencer, ... every editor operates on selection. The problem here is that this is no selection, but looks like one. I'm not sure what being active entails for a modifier, but I think the indicator should be proportional to its importance. If we're going to have shortcuts affects the hovered modifier, then there needs to be a hover indicator that's more prominent than the active indicator.
Author
Member
Added subscribers: @WilliamReynish, @pablovazquez
Author
Member
Yes, totally agreed @hadrien, I'd like to find a better way to indicate the active modifier.
Another reason it could be less prominent is that it only has an effect for nodes moidifiers, not any other types.
Unfortunately it doesn't seem like there's any very elegant way to do this, but maybe we'll just have to accept that.
Some more ideas I talked about with @WilliamReynish:
Yes, totally agreed @hadrien, I'd like to find a better way to indicate the active modifier. Another reason it could be less prominent is that it only has an effect for nodes moidifiers, not any other types. Unfortunately it doesn't seem like there's any very elegant way to do this, but maybe we'll just have to accept that. Some more ideas I talked about with @WilliamReynish: ![image.png](https://archive.blender.org/developer/F9915829/image.png) ![image.png](https://archive.blender.org/developer/F9915833/image.png) ![image.png](https://archive.blender.org/developer/F9915831/image.png)
Added subscriber: @Lumpengnom-3
There are other areas where shortcuts do not affect what is selected or active. For example in edit mesh mode "select linked" - Shortcut "L".
If you hover over a mesh island and press "L" the island is selected while the active or selected part of the mesh is not selected.
IMO having hover shortcuts like these is very useful and not inconsistent with the UI.
Having some sort of hover indicator seems useful, too but imo not necessary.
There are other areas where shortcuts do not affect what is selected or active. For example in edit mesh mode "select linked" - Shortcut "L". If you hover over a mesh island and press "L" the island is selected while the active or selected part of the mesh is not selected. IMO having hover shortcuts like these is very useful and not inconsistent with the UI. Having some sort of hover indicator seems useful, too but imo not necessary.
@HooglyBoogly The radio button idea is consistent with other places in Blender (fcurve modifiers) and it serves that it's an explicit button instead of an "invisible-hitbox" activation like in 2.92. It's further less horizontal space in a place that's running out of it already though (unless the new datablock selector goes in as well?)
@Lumpengnom-3 sure what I mean is there's a visual sign -the outline- that suggests the operation is going to happen on it, because that's a code used Blender-wide. I'm not saying it's the only one, it's just a thing that users are most definitely expecting.
@HooglyBoogly The radio button idea is consistent with other places in Blender (fcurve modifiers) and it serves that it's an explicit button instead of an "invisible-hitbox" activation like in 2.92. It's further less horizontal space in a place that's running out of it already though (unless the new datablock selector goes in as well?) @Lumpengnom-3 sure what I mean is there's a visual sign -the outline- that suggests the operation is going to happen on it, because that's a code used Blender-wide. I'm not saying it's the only one, it's just a thing that users are most definitely expecting.
Member
Member
Is this done?
Is this done?
Member
Added subscriber: @lichtwerk
Member
Looks like it 9f323e9bf7, unfortunately this also caused #87264 (Physics (Collision, Cloth, Dynamic Paint, Soft Body, Fluid) cannot be removed (X button disfunctional))
Author
Member
I'd like to propose the radio button idea to the team instead of the blue highlight, but that can be a separate task.
I'll commit the fix to the bug @lichtwerk mentioned in a few minutes.
I'd like to propose the radio button idea to the team instead of the blue highlight, but that can be a separate task. I'll commit the fix to the bug @lichtwerk mentioned in a few minutes.
Thomas Dinges added this to the 2.93 LTS milestone 2023-02-07 18:46:14 +01:00
7 Participants
Reference: blender/blender#87012
