Sapling Tree Gen DupliVerts/Armature Problems #87071
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#87071
Graphics card: Radeon RX 580 Series ATI Technologies Inc. 4.5.14760 Core Profile Context 21.2.3 27.20.14535.3005
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
blender/blender@02948a2cab
Addon Information
Name: Sapling Tree Gen (0, 3, 4)
Author: Andrew Hale (TrumanBlending), Aaron Buchler, CansecoGPC
When I use add armature all of the leaves on my tree stand straight up and can't be animated. None of the leaf scale options seem to work either. This happens no matter which object I use as a leaf.
Sapling Tree Gen won't let you edit properties after you close the tab so I don't think a blend file would help much in this case but I'll link anyways.
Add Curve -> Sapling Tree Gen -> Leaves tab -> Show leaves -> Leaf Shape: DupliVerts -> Leaf object: [Plane object] -> Armature tab -> Use Armature. At this point all of the leaves stand straight up and won't animate.
Appreciate the help.
saplingtreebug.blend
Added subscriber: @memoryband
Added subscriber: @wossen-gebeyehu
Added subscriber: @smereces
Same problem here! Using leaves from a custom object,after we add the armature the leaves positions and rotations before get all broked and the leaves shows facing all up in the same direction! right now for animation this is useless as is it if we want to use our custom leaves!! can you please fix this issue
Added subscriber: @OmarEmaraDev
Is the issue that the custom object is always pointing in a certain direction regardless of the pose or animation? In that case, this is probably expected because DupliVerts does not encode any rotation value. You should probably use DupliFaces.
Just a poke regarding my inquiry above, otherwise, we will have to archive this for now.
Using DupliFaces worked, thanks for the tip
