Attribute Compare node is writing vertex-groups with no weight. #87102
Reference: blender/blender#87102
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-03-31 07:46, hash:
645fc0c767
If we are using geometry node to do some vertex-group manipulation,
using attr compare will write a vertex-group with no weight.
In the blend file below, you will see an example of this behavior, the spreadsheet show weight, but none of the values are transferred to the vertex group
attrcomparevg.blend
Added subscriber: @dodododorian
Added subscriber: @mano-wii
I'm not sure exactly how it works, but attribute B is actually being overwritten. So it looks like a bug to me.
Added subscriber: @wannes.malfait
It seems that this is caused by the return type of the compare node being a
boolean
attribute, while the vertex group is afloat
attribute. Since the types don't match, a newSpan
is created (with the same name), instead of overwriting the vertex group using an implicit conversion. From then on, the attributeB
refers to thatSpan
and not the vertex group. There are multiple ways around this, but I'm not sure if this should be considered intended behaviour.Alternative 1:
Use the
Attribute Math
node instead (returnfloat
attribute so this overwrites)Alternative 2:
Use a temporary attribute, and then overwrite with the attribute convert node.
Why is the attr convert node not working then?
After the
Attribute Compare Node
the attributeB
refers to a newboolean
attribute that has nothing to do with the vertex groupB
. TheAttribute Convert
node only modifies this new attribute, and not the vertex group. Due to the fact that they have the same name (B
) the vertex group is no longer accessible in the node tree, as any use of the the nameB
will refer to theboolean
attribute instead.Like I said, this is not very intuitive, and should probably be changed.
This is actually working as expected. There can't be two attributes with the same name and different types. We could change the output type of the attribute compare node, but I'm not sure we should. Either way, this is not a bug, so I'm closing this report. The alternative of using a separate attribute for intermediate computations makes sense to me.
