Dynamic Paint Substeps don't work #87275
Reference: blender/blender#87275
Operating system: MacOS Big Sur 11.2.2
Graphics card: Intel Iris Plus Graphics 1536 MB
Broken: 2.92.0 (release)
Worked: ?
When I use substeps for Dynamic Paint it doesn't make a difference in the images generated.
Add particle system to default cube
Turn the cube into a Dynamic Paint Brush, set Source to Particle System, Particle System to "ParticleSettings"
Add in a plane and scale it by 4
Turn the plane into a Dynamic Paint Canvas, set Format it to image
Set Sub-Steps to 20 (maximum)
(Optional: Set Plane cache path to something reasonable you would find later)
Click "Bake Image Sequence"
(Optional: Set Sub-Steps to 0 (minimum)
(Optional: Set Plane cache path to something different than before)
(Optional: Click "Bake Image Sequence")
(Optional: Compare baked images)
If you compare 0 Sub-Steps to 20 Sub-Steps they look the same; I think Sub-Steps has no influence on the result whatsoever.
Based on the default startup or an attached .blend file (as simple as possible). bug_dynamic_paint_substeps.blend
Added subscriber: @gogo
Added subscriber: @lichtwerk
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
In code, it looks like only the brush objects (so
Source
being anything butParticle System
) are updated specifically for each subframe.Afaict, their particle data is not available in subframes for dynamic paint to use though.
It would be nice to somehow have that data available [maybe in conjunction with specifying a higher value for
>Integration
>Subframes
on the particle system], but this would be more like a feature request (which is not handled in this bugtracker).I am not 100% sure though if this is by design, so will have the module devs have a confirming look...
It was working in 2.97 so i don't consider it a feature request; maybe it's a degradation?
Changed status from 'Needs Developer To Reproduce' to: 'Needs Triage'
Thx getting back, will double-check then.
@lichtwerk , possibly the report is similar to #85523 (Dynamic Paint sub-steps doesn't work with particles)
Yes, indeed, thx catching that, will merge these reports
Closed as duplicate of #85523
