Object selection before Vertex Groups weight painting for Bones
Needs Triage, NormalPublic
In the 2.92 manuel, in
Modeling/Sculpting & Painting/Modes/Weight Paint/Using Vertex Groups/Vertex Groups for Bones
It is said:
Select the armature in 3D Viewport, and bring the >armature to Pose Mode with Ctrl-Tab, or the 3D >Viewport header mode selector.
Select a desired bone in the armature.
Select your mesh with LMB and change immediately >to Weight Paint Mode. The >mesh will be colored according to the weight (degree) that the selected bone >movement affects the mesh. Initially, it will be all blue (no effect).
I think in 2.92 Blender version that's impossible.
Instead you have to select the armature in object mode and add the mesh object to the selection, and change immediately to Weight Paint Mode.
Aaron Carlisle (Blendify) changed the task status from Needs Triage to Needs Information from User.Apr 12 2021, 5:34 PM
This should be fixed with rBM7784 can you confirm that the behavior described in the 2.93 user manual: https://docs.blender.org/manual/en/2.93/ works as expected.
Actually the issue is in the manuel.
You have to exit the Pose Mode to select a Mesh object in the 2.8 and 2.9 Blender versions.
First you select the armature, you don't bring it to Pose Mode,
instead you add the Mesh to the selection to set it the active object
and you change from Object Mode to Weight Paint Mode and then the description in the manuel is correct.
The issue of the manuel I want to report is not how to select the bones while Weight painting
That has been effectively fixed in rBM7784.
But to be able to select the bones in the weight Paint mode of the mesh,
the armature must be "activated" in some way and the way described in the manuel is wrong in my opinion.
Ankit Meel (ankitm) changed the task status from Needs Information from User to Needs Triage.Wed, Apr 28, 3:43 PM
