EEVEE - Specular Light Viewport Render Pass Behavior (AO and Screenspace Reflection - Over-Darkening Effect on Metallic Object) #87440
Closed
opened 2021-04-12 19:59:37 +02:00 by Macc · 11 comments
Operating system: Windows-10
Graphics card: GeForce GTX 960M
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-04-10 16:36, hash: ed5507de8a
With Metallic objects, New Screenspace reflections and AO implementation (or another cause or bug is maybe the reason) creates over-darkening and unexpected results (when there is a metallic object) that can also be seen on Specular Light Pass from viewport passes as well as just by looking at a metallic object in combined pass
2.93 Combined Viewport Render Pass - Metallic object - DARK Ambient Occlusion on Specular Surfaces.png 2.92 Combined Viewport Render Pass - Metallic object.png
2.93 Specular Light Pass - AO enabled.png 2.92 Specular Light Pass - AO enabled.png
2.93 Specular Light Pass - AO and SSR enabled.png 2.92 Specular Light Pass - AO and SSR enabled.png
  • Open attached file or:
  • Create a plane without adding or changing its material and scale by 5 and move -1 (down)
  • Edit the material of default cube and set metallic value to 1
  • Ensure viewport shading settings do not use scene world but use the forest HDRI and maximize world opacity and remove blur
  • Then in Render Pass set the Specular Light pass for example
  • Go to properties and first activate ambient occlusion - (it will make it everything over-dark)
  • then second activate screenspace reflections and - (it will make everything dark on specular light pass)
  • Also Go to combined pass of viewport- the metal cube will have strange dark shadows and darker reflections due when u use AO+SSR
    !! Compare this with 2.92.0 and there specular light pass is working properly and metal cube doesnt have strange over-dark look etc. when AO and SSR is active
    eevee_ssr_bug.blend
**System Information** Operating system: Windows-10 Graphics card: GeForce GTX 960M **Blender Version** Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-04-10 16:36, hash: `ed5507de8a` Worked: (newest version of Blender that worked as expected) **Short description of error** With Metallic objects, New Screenspace reflections and AO implementation (or another cause or bug is maybe the reason) creates over-darkening and unexpected results (when there is a metallic object) that can also be seen on Specular Light Pass from viewport passes as well as just by looking at a metallic object in combined pass |![2.93 Combined Viewport Render Pass - Metallic object - DARK Ambient Occlusion on Specular Surfaces.png](https://archive.blender.org/developer/F9930929/2.93_Combined_Viewport_Render_Pass_-_Metallic_object_-_DARK_Ambient_Occlusion_on_Specular_Surfaces.png)|![2.92 Combined Viewport Render Pass - Metallic object.png](https://archive.blender.org/developer/F9930928/2.92_Combined_Viewport_Render_Pass_-_Metallic_object.png) | -- | -- | |![2.93 Specular Light Pass - AO enabled.png](https://archive.blender.org/developer/F9930904/2.93_Specular_Light_Pass_-_AO_enabled.png)|![2.92 Specular Light Pass - AO enabled.png](https://archive.blender.org/developer/F9930903/2.92_Specular_Light_Pass_-_AO_enabled.png) |![2.93 Specular Light Pass - AO and SSR enabled.png](https://archive.blender.org/developer/F9930911/2.93_Specular_Light_Pass_-_AO_and_SSR_enabled.png)|![2.92 Specular Light Pass - AO and SSR enabled.png](https://archive.blender.org/developer/F9930910/2.92_Specular_Light_Pass_-_AO_and_SSR_enabled.png) **Exact steps for others to reproduce the error** - Open attached file or: - Create a plane without adding or changing its material and scale by 5 and move -1 (down) - Edit the material of default cube and set metallic value to 1 - Ensure viewport shading settings do not use scene world but use the forest HDRI and maximize world opacity and remove blur - Then in Render Pass set the Specular Light pass for example - Go to properties and first activate ambient occlusion - (it will make it everything over-dark) - then second activate screenspace reflections and - (it will make everything dark on specular light pass) - Also Go to combined pass of viewport- the metal cube will have strange dark shadows and darker reflections due when u use AO+SSR !! Compare this with 2.92.0 and there specular light pass is working properly and metal cube doesnt have strange over-dark look etc. when AO and SSR is active [eevee_ssr_bug.blend](https://archive.blender.org/developer/F9935142/eevee_ssr_bug.blend)
Author
Added subscriber: @MCAN
#86036 was marked as duplicate of this issue
Macc changed title from EEVEE - Specular Pass (AO and Screenspace Reflection - Darkening Effect on Metallic Object) to EEVEE - Specular Light Viewport Pass (AO and Screenspace Reflection - Darkening Effect on Metallic Object) 2021-04-12 20:04:30 +02:00
Macc changed title from EEVEE - Specular Light Viewport Pass (AO and Screenspace Reflection - Darkening Effect on Metallic Object) to EEVEE - Specular Light Viewport Render Pass (AO and Screenspace Reflection - Darkening Effect on Metallic Object) 2021-04-12 20:04:49 +02:00
Macc changed title from EEVEE - Specular Light Viewport Render Pass (AO and Screenspace Reflection - Darkening Effect on Metallic Object) to EEVEE - Specular Light Viewport Render Pass Behavior (AO and Screenspace Reflection - Over-Darkening Effect on Metallic Object) 2021-04-12 20:27:53 +02:00
Added subscriber: @mano-wii
Thanks for the report, I can confirm.
Author
You are welcome.
You are welcome.
Added subscriber: @geocentric_wage
Member
Added subscriber: @Jeroen-Bakker
This issue was referenced by 3735986e87
This issue was referenced by 3735986e875981e5525ec8cec379023abcc692bf
Clément Foucault self-assigned this 2021-04-20 17:45:47 +02:00
Added subscriber: @EAW
6 Participants
Reference: blender/blender#87440
