Cycles: Attribute node renders black when some reserved standard attribute names are used #87494
Open
opened 2021-04-14 16:37:08 +02:00 by Germano Cavalcante · 26 comments
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.14760 Core Profile Context 20.45.37.01 27.20.14537.1001
Broken: 2.79 - 2.93.0 Alpha, branch: master, commit date: 2021-04-14 02:19, hash: 6776b74d0a
Worked: Never?
In Cycles, the Attribute node returns black when an attribute name is reserved (such as "color" or "temperature").
The attribute can be created from the attribute panel or through Geometry Nodes.
Seems like any these attribute names could cause the issue:
https://projects.blender.org/blender/blender/src/branch/main/intern/cycles/scene/attribute.cpp#L320-L392
  • Open attached file
  • Display render preview (note that the object is black)
  • Change the name on the node attribute and Vertex Color to "color2" (or switch to node having "temp" attribute)
    Now the node attribute works
vcol_cycles_name_bug.blend
temperature_attribute_shader_handling.blend
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.14760 Core Profile Context 20.45.37.01 27.20.14537.1001 **Blender Version** Broken: 2.79 - 2.93.0 Alpha, branch: master, commit date: 2021-04-14 02:19, hash: `6776b74d0a` Worked: Never? **Short description of error** In Cycles, the Attribute node returns black when an attribute name is reserved (such as "color" or "temperature"). The attribute can be created from the attribute panel or through Geometry Nodes. Seems like any these attribute names could cause the issue: https://projects.blender.org/blender/blender/src/branch/main/intern/cycles/scene/attribute.cpp#L320-L392 **Exact steps for others to reproduce the error** - Open attached file - Display render preview (note that the object is black) - Change the name on the node attribute and Vertex Color to "color2" (or switch to node having "temp" attribute) Now the node attribute works [vcol_cycles_name_bug.blend](https://archive.blender.org/developer/F9933464/vcol_cycles_name_bug.blend) [temperature_attribute_shader_handling.blend](https://projects.blender.org/attachments/8bb74567-193d-4a5e-8e06-8ff2215390d4)
Author
Member
Added subscriber: @mano-wii
#101880 was marked as duplicate of this issue
#101037 was marked as duplicate of this issue
#100193 was marked as duplicate of this issue
#99582 was marked as duplicate of this issue
#93531 was marked as duplicate of this issue
#95168 was marked as duplicate of this issue
#94988 was marked as duplicate of this issue
#92116 was marked as duplicate of this issue
#87373 was marked as duplicate of this issue
Author
Member
Author
Member
Apparently this is related to built-in attributes as seen in https://blender.stackexchange.com/questions/14262/what-can-you-call-from-the-attribute-node#14267
Author
Member
Added subscribers: @slowburn, @CharlieJolly
I just wanted to clarify that this is not limited to vertex colors. Thanks to a recently added feature, custom attributes created in geometry nodes can be used directly in Cycles without the need for vertex colors: https://developer.blender.org/rB3a6d6299d
Maybe the fix will apply to GN as well, but I think it would be good if you could modify the name or description of this task to indicate that it also affects geometry nodes, since you closed my task.
I just wanted to clarify that this is not limited to vertex colors. Thanks to a recently added feature, custom attributes created in geometry nodes can be used directly in Cycles without the need for vertex colors: https://developer.blender.org/rB3a6d6299d Maybe the fix will apply to GN as well, but I think it would be good if you could modify the name or description of this task to indicate that it also affects geometry nodes, since you closed my task.
Member
Added subscribers: @barakooda, @EAW
Added subscribers: @1029910278, @HooglyBoogly
Added subscribers: @MysteryPancake, @kevindietrich, @lichtwerk
Philipp Oeser changed title from Attribute node does not work in Cycles when referencing a Vertex Color named "color" to Attribute node does not work in Cycles (renders black) when some reserved standard attribute names (such as "color") are used 2022-01-24 12:39:52 +01:00
Author
Member
Added subscribers: @OrestisKonstantinidis, @null
Member
Added subscriber: @shadow_creeper
Contributor
Removed subscriber: @MysteryPancake
Member
Added subscriber: @OmarEmaraDev
Member
Added subscriber: @Matthias-Schafer
Author
Member
Added subscriber: @SteffenD
Contributor
Added subscriber: @dupoxy
Contributor
still true it seems ... I was about to fill a new bug report using this file: reT87494.blend
still true it seems ... I was about to fill a new bug report using this file: [reT87494.blend](https://archive.blender.org/developer/F14197973/reT87494.blend) ![Capture d’écran 2023-01-25 à 19.10.50.png](https://archive.blender.org/developer/F14197976/Capture_d_e_cran_2023-01-25_a__19.10.50.png)
Philipp Oeser removed the
label 2023-02-09 14:02:28 +01:00
Pratik Borhade changed title from Attribute node does not work in Cycles (renders black) when some reserved standard attribute names (such as "color") are used to Cycles: Attribute node renders black when some reserved standard attribute names are used 2023-08-07 10:27:56 +02:00
Member
This is also valid for "temperature" attribute (I've included those changes in title/description).
ada738ac7c has fixed the EEVEE part of it but cycles still renders black output.
This is also valid for "temperature" attribute (I've included those changes in title/description). ada738ac7cfaea3de986e9837cf33905a59762cd has fixed the EEVEE part of it but cycles still renders black output.
10 Participants
Reference: blender/blender#87494
