Problem with the world background strength #87568
Reference: blender/blender#87568
Operating system: Windows 10
Graphics card: RTX 2060 Super
Broken: 2.93 Beta,
fa8d566c3b
, master, 2021-04-15,Short description of error
When you change the strength of the background node, it doesn't change in the render
Added subscriber: @Benianus
Added subscribers: @brecht, @Alaska
Are you using the "Persistent Data" setting? If so, that's probably the cause (I can reproduce your issue if I enable persistent data):
If that is the cause, then it's probably related to #87535 (Persistent Data ignores light objects property changes) and #87295 (Persistent Data ignores animation)
CC @brecht Should these reports be merged?
Depends if it's related to the persistent data option.
Without steps to reproduce or an example .blend we can't tell.
I tryed what alaska says, and it's right, it's because of the persistent data option,
It's ok with light objects, but the problem still in with the world background strength
This will likely be fixed in tomorrow's build along with #87535 (Persistent Data ignores light objects property changes).
Testing with 3.0.0 Alpha
795f024558
2021-04-19 20:49 the issue is fixed.@Benianus are you able to confirm? (As Brecht said, you may need to wait a day or so before a build is available with this fix from https://builder.blender.org/ in either Blender 3.0 or 2.93)
Problem solved, confirmed in 2.93 Beta & 3.0 Alpha
thank you very much
Changed status from 'Needs User Info' to: 'Resolved'
