sculpt pose brush ignores fase set automasking
Closed, ResolvedPublicBUG
Operating system: linux
Graphics card: intel
Broken: 2.93.0-9b87d3f02962-linux64
sculpt pose brush affects whole mesh, regardless of the face set automasking setting
Based on the attached .blend file
Open attached blend file, check that sculpt pose brush is selected and face set automasking is turned on:
Bend the faceset-marked top mesh part with the pose brush:
Result: the bottom (white) part of the mesh also affected, despite the fact that it does not belong to face set:
Expected result: bottom part vertices should stay in place. For example this is correct result of applying elastic deform brush to the top part:
Side note: the pose brush correctly avoids box mask, it should do the same for face set automasking, when it is on
