Needs two clicks with Ctrl or Shift key to deselect an item from a list of selected items #87642
Reference: blender/blender#87642
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
Needs two clicks with Ctrl or Shift key to deselect an item from a list of selected items.
The same problem happens in different views with different details.
Outliner:
3D View:
The Shift key is used to select/deselect objects individually. It is pretty much the same issue. It requires two clicks on the same object to really deselect the object, whatever the order of the object in the selection. However, if one object has already been selected before deselecting everything, then the same object gets selected with an additional highlight from the new selection (dragging the mouse cursor in the viewport).
Shading view:
Pretty similar to the 3D view.
If I deselect all the nodes (Alt + A for example) and I drag the mouse cursor to select all nodes, the last selected node is highlighted in white. If I click the node highlighted in white while holding the Shift key, the node is deselected. However, if I do the same thing for the other nodes, it selects the node with a white highlight and I have to click a second time on the same node to really deselect it. The behavior of the last selected item is also present in the 3D View, but not for the Outliner.
The Compositing view has the same problem and I suspect that the Geometry Node view has the same too (I haven’t tested the last one).
In general, it requires two clicks to deselect an object with the normal behavior.
The first click behaves as an “add to selection” click unless the object already had a selection before completely creating a new selection.
In all cases, there is an issue with deselecting (or excluding) and single object from a selection of objects in different views. As a reference how it should behave correctly, the Windows Explorer in Windows is able to deselect a single item on the first time it is clicked.
OutlinerSelectItemWithCtrl.blend
Deselect_Issue.mp4
Added subscriber: @SebBlender
Added subscriber: @DanPool
Not really a bug. The first click makes the clicked object the active object. The second click deselects it. I feel this is not great behavior and the first click on a shift-click should deselect the object. However, we still need a way to change which object is the active object.
It might not be a bug, but certainly it is an issue. There are two things important to highlight.
When looking at other applications on Windows, and probably other operating systems, it works in a more direct way. Holding the Ctrl key when clicking any item deselects the item without this notion of an already selected item from a previous selection.
Yes, it seems to have an active object being taken into account. However, it is cumbersome to have to check if the object is already selected. If I don’t check that, I still have to check if I need to click a second time on the object. It is certainly not productive.
After making many tests, there seems to have this notion of an active object already selected before influencing the new selection. If someone doesn’t know that, they will try to manage the selection with what is already known with 99% and + of other programs.
I’m aware that Blender has a more special interface design. However, I reported it because it did not work as I expected. The list selection management is something that I consider standard in terms of UI design.
Thanks for the report. Not sure if this is intended behavior or not, so adding module tag.
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
