Selecting a Add Shader node in the Shader Editor window no longer highlights Shader Node line in Dope Sheet window #88037
Reference: blender/blender#88037
Operating system: Windows 10
Graphics card: RTX1050
Broken: 2.91, 2.92, 2.93, 3.0.0
Worked: 2.83
Caused by
c5bdbc340a
Selecting an Add Shader Node containing keyframes would automatically highlight the corresponding Shader Node line in the Dope Sheet window
Add two or more "Add Shader" nodes to the Shader Editor window. Set a keyframe for each of the Add Shader nodes.
Open the Dope Sheet window and view the ShaderNodetree lines have been added with corresponding keyframes.
Version 2.83 - Clicking on each of the Add Shader nodes in the Shader Editor window will highlight the corresponding ShaderNodetree row in the Dope Sheet window.
Versions after 2.83 - Clicking on each of the Add Shader nodes in the Shader Editor window no longer lighlights the corresponding ShaderNodetree row in the Dope Sheet window.
Added subscriber: @SteveRS
Thanks, SteveRS
Added subscriber: @lichtwerk
Can confirm, will check.
Added subscriber: @dr.sybren
Caused by
c5bdbc340a
Reading https://devtalk.blender.org/t/responding-to-selection-changes/15813 or
#74159 (Fix Animation Channel Selection Sync) I am not sure what the current status of this is (since it was meant to be "a temporary situation") @dr.sybren ?
Has any of the proposed design mentioned in the devtalk thread been implemented to be used as a reference here?
If not, is the design still valid to be implemented?
@dr.sybren should this be closed or marked as a known issue?
since the report has been made, the channel text has been improved so you can actually know which material/node a channel animates
e.g.
Object selection still syncs, which is desired. But I think reverting back to syncing channel selection based on nodes is a bad idea.
I agree. The selection syncing of pose bones with the animation data is troublesome as well, and thus care should be taken to introduce similar syncing in other areas.
