Eevee: math wrap and floor, AMD Driver precision issues #88151
Reference: blender/blender#88151
Graphics card: Radeon RX 5500 XT ATI Technologies Inc. 4.5.14831 Core Profile Context 21.5.1 27.20.21003.1028
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
Blender 2.83 LTS has same problem
Math and Vector Wrap give different results for Eevee and Cycles, also doesn't swap min max, when max is less than min
More info
This is important for an upcoming Shader Nodes patch that relies on wrap operation
also for shader setups that rely on this
other people tested this, the problem seems to appear only on AMD Windows
When Using -3 as Min for wrap, and 3 as max, some values give different results in Eevee than in Cycles
Floor operation is probably the cause of this
this node setup
Eevee
eevee_math_wrap_different_from_cycles.blend
Added subscriber: @IyadAhmed
Math Node Wrap: Different results for Eevee and Cycles, also doesn't swap min max, when max is less than minto Wrap math operation: Different results for Eevee and Cyclesit seems to be only on AMD/Windows configuration
Wrap math operation: Different results for Eevee and Cyclesto Eevee: wrong results for wrap math operation with AMD WindowsEevee: wrong results for wrap math operation with AMD Windowsto Eevee: wrong results for wrap and floor math with AMD WindowsEevee: wrong results for wrap and floor math with AMD Windowsto Eevee: wrong results for wrap and floor math with AMD GPU WindowsMultiple people with non-AMD/non-Windows tested and the issue was not happening for them
Eevee: wrong results for wrap and floor math with AMD GPU Windowsto Eevee: math wrap and floor, AMD Driver precision issuesAdded subscriber: @Jeroen-Bakker
Added subscriber: @OmarEmaraDev
I can replicate the issue on Mesa R600g. Software rasterization is identical to Cycles. I can take a look later today.
Great
Added subscriber: @CharlieJolly
@CharlieJolly The max and min inputs of the wrap function seems to be inverted, at least relative to the Godot code, is that intended? Also can you take a look at this?
@IyadAhmed Seems to be a precision issue indeed.
floor((value - minValue) / (maxValue - minValue))
may be zero when it should ideally be 1 for off-one-division results. Not sure what should be done here. Lets wait for Charlie's opinion on this.Great, many thanks for working on the issue
Also for swapped values, max and min should be swapped when max is less than min I think
Works fine here on Windows/Intel.
The inputs are swapped around probably to match the UI parameter order which uses a, b and c.
Probably is a precision issue. Division by zero should be avoided as
range
is checked before the divide operation.Min, max values could be swapped but this is a change in behaviour.
I can't test AMD here unfortunately.
another observation, adding a small value before wrap produces wrong results both on Cycles and Eevee, possibly on non-AMD as well
The code is consistent. I think the sockets maybe labelled incorrectly. Not sure why this happened, could be oversight in original patch. The bug then maybe caused by the issue that max is less than min.
@IyadAhmed Can you check again but swapping min and max. Can you also check with OSL too?
Sure swapping is same problem, this is a different problem than with AMD driver, it happens on all
to make it clear adding a small value to input, makes it always act as if max is less than min, even if you write values swapped
OSL
here's "correct" result for comparison
Here is a file with a nodegroup implementing the wrap function that may help troubleshoot the issue. The labels are an easy fix but perhaps leave that until this bug is fixed.
eevee_math_wrap_different_from_cycles_v2.blend
I don't think I can help anymore without an AMD card to test.
Cycles (OSL same results as non-OSL)
Eevee
Produces different results
