Eevee not working with AMD RX580 #88180
Closed
opened 2021-05-10 16:37:56 +02:00 by Ramil Roosileht · 7 comments
Operating system: 'Windows-10-10.0.19041-SP0'
Graphics card: 'AMD Radeon (TM) RX 580X' '4.5.14830 Core Profile Context 21.4.1 27.20.21002.112'
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-05-09 06:33, hash: f694321db0, type: Release
Worked: never
Eevee shows artifacts and meshes are broken until you enable "High Quality Normals" checkbox. By default it is not enabled.
  • Have a PC with similar config (Win10, i5 8400, RX580) and latest drivers
  • Launch Blender
  • Change to material preview or rendered mode (default startup file)
  • See that default cube is made out of artifacts
See system info and video for details
system-info (1).txt
AMDEeveeBug.mp4
**System Information** Operating system: 'Windows-10-10.0.19041-SP0' Graphics card: 'AMD Radeon (TM) RX 580X' '4.5.14830 Core Profile Context 21.4.1 27.20.21002.112' **Blender Version** Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-05-09 06:33, hash: f694321db073, type: Release Worked: never **Short description of error** Eevee shows artifacts and meshes are broken until you enable "High Quality Normals" checkbox. By default it is not enabled. **Exact steps for others to reproduce the error** - Have a PC with similar config (Win10, i5 8400, RX580) and latest drivers - Launch Blender - Change to material preview or rendered mode (default startup file) - See that default cube is made out of artifacts **See system info and video for details** [system-info (1).txt](https://archive.blender.org/developer/F10076061/system-info__1_.txt) [AMDEeveeBug.mp4](https://archive.blender.org/developer/F10076107/AMDEeveeBug.mp4)
Author
Member
Added subscriber: @Limarest
Member
Added subscriber: @Jeroen-Bakker
Jeroen Bakker self-assigned this 2021-05-10 16:45:24 +02:00
Member
GPU capabilities needs to be updated. for this. Related to #82856 (After updating the video card drivers to 20.11.2, interface artifacts appeared.)
Should be done for 2.83 and 2.93.
I will keep this a separate ticket as the GPU name needs to be added to the current work around.
GPU capabilities needs to be updated. for this. Related to #82856 (After updating the video card drivers to 20.11.2, interface artifacts appeared.) Should be done for 2.83 and 2.93. I will keep this a separate ticket as the GPU name needs to be added to the current work around.
Member
This issue was referenced by b779fae993
This issue was referenced by b779fae9934598f41efd23d3df9331600f53c99f
This issue was referenced by e76b43efcf
This issue was referenced by e76b43efcfafb5da02679325c49f46d833ded4e9
Member
Thomas Dinges added this to the 2.83 LTS milestone 2023-02-08 16:35:26 +01:00
Reference: blender/blender#88180
