alembic attributes doesn't respect alembic standard #88275
Reference: blender/blender#88275
Operating system: All
Graphics card: Nvidia RTX 2080Ti (x8)
Broken: 2.92.0 Master
blender export of custom properties is not right
.userProperties
of an object, so for instance in the example/Cube.userProperties.static_int
which is an ArrayProperty.this makes data unreadable or can crash some others DCCs
ex : what maya can see
we should be able to choose if properties are at xform or shape level and default must be on shape normally
add custom attributes on objects
export alembic with custom attributes on
inspect the alembic with abcls
custom-properties.blend custom-properties.abc
Added subscriber: @kaiz3r
alembic attributesto alembic attributes doesn't repect alembic standardalembic attributes doesn't repect alembic standardto alembic attributes doesn't respect alembic standardAdded subscriber: @lichtwerk
Seems alembic export supports Custom Properties on the
Mesh
datablock (shape level) as well?#88275.abc
#88275.blend
Doesnt this work for you?
You have the choice to put it on the object (transform level), the object data / Mesh (shape level) or both. Dont think we need a "standard" here if we can put it on both?
If there is a standard for this, is this defined anywhere?
my mistake, it's the .arbGeomParam that needs to be on shape level...
thank you for the example files
I can confirm that, with your export too, the alembic can cause crash because of array being non scalar
is there a way to export as arbGeomParam in blender to compare it with maya ?
here is an abc from maya, that export by default attribute to arbGeomParam and that work in all our DCCs
custom-propertiesMAYA.abc
Sorry it took a bit to answer.
Trying to understand better:
Not sure why that is? Both your provided abc and the one I exported write scalars in to single-element arrays, found this comment:
So it seems to come down to
.userProperties
vs.arbGeomParams
.Or does this mean we are not allowed to write single-element arrays into
.userProperties
?Found this other related comment:
Having said that, what I find strange is that a
CompoundProperty
.arbGeomParams
is always defined by blender, but then empty?Do you have any reference or document where this standard is described?
Here is an abc with Custom Properties written to
arbGeomParams
T88275_arbGeomParams.abc
Does this also crash?
(this was done changing https://developer.blender.org/diffusion/B/browse/master/source/blender/io/alembic/exporter/abc_writer_abstract.h$113)
P2131: T88275_snippet
(this seems to be related to exporting UVs btw. not exporting UVs will also not define .arbGeomParams -- still find it strange...)
@kaiz3r : could you check the above please? (otherwise will be closed in a week)
@lichtwerk can you close the report?
@kaiz3r : feel free to comment again if you could check/answer the above, wil archive for now though.
