Proportional transform scale does not show small values #88346
Closed
opened 2021-05-17 11:46:35 +02:00 by george b · 5 comments
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 462.31
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: 02948a2cab
Worked: ?
The problem
When activating Proportional Editing with objects sized in centimeter range, the influence circle is way to big, out of the screen and you need to scale it a lot with scroll .
This is very slow with high poly meshes (500k to 1M triangles).
Adjusting the proportional size for small areas just shows 0.00.
Users expect that default influence should be initialized relative to screen size or to object size.
  • Enable Proportional Editing
  • After adjusting the Proportional size value for 1 cm or less of influence the onscreen value for proportional shows just 0.00.
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 462.31 **Blender Version** Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: `02948a2cab` Worked: ? **The problem** When activating Proportional Editing with objects sized in centimeter range, the influence circle is way to big, out of the screen and you need to scale it a lot with scroll . This is very slow with high poly meshes (500k to 1M triangles). Adjusting the proportional size for small areas just shows 0.00. Users expect that default influence should be initialized relative to screen size or to object size. **Exact steps for others to reproduce the error** - Enable Proportional Editing - After adjusting the Proportional size value for 1 cm or less of influence the onscreen value for proportional shows just 0.00.
Author
Added subscriber: @GeRo
Added subscribers: @mont29, @mano-wii
This is not really a bug, but a design issue.
We could solve this by supporting units in the proportional editing value:
diff --git a/source/blender/editors/transform/transform_mode_translate.c b/source/blender/editors/transform/transform_mode_translate.c
index 3088f6a7776..8f7ef4ae4c2 100644
--- a/source/blender/editors/transform/transform_mode_translate.c
+++ b/source/blender/editors/transform/transform_mode_translate.c
@@ -201,8 +201,19 @@ static void headerTranslation(TransInfo *t, const float vec[3], char str[UI_MAX_
   if (t->flag & T_PROP_EDIT_ALL) {
-    ofs += BLI_snprintf_rlen(
-        str + ofs, UI_MAX_DRAW_STR - ofs, TIP_(" Proportional size: %.2f"), t->prop_size);
+    ofs += BLI_strncpy_rlen(str + ofs, TIP_(" Proportional size: "), UI_MAX_DRAW_STR - ofs);
+    if (unit) {
+      ofs += BKE_unit_value_as_string(str + ofs,
+                                      UI_MAX_DRAW_STR - ofs,
+                                      t->prop_size * unit->scale_length,
+                                      4,
+                                      B_UNIT_LENGTH,
+                                      unit,
+                                      false);
+    else {
+      ofs += BLI_snprintf_rlen(str + ofs, UI_MAX_DRAW_STR - ofs, "%.2f", t->prop_size);
   if (t->spacetype == SPACE_NODE) {
But with this change, we would lose translations of " Proportional size: %.2f".
I don't know to what extent such a change justifies losing some translations.
@mont29, (you know the translations area better), is there any way to get around the problem of losing translations? And is this really a problem?
This is not really a bug, but a design issue. We could solve this by supporting units in the proportional editing value: ``` diff --git a/source/blender/editors/transform/transform_mode_translate.c b/source/blender/editors/transform/transform_mode_translate.c index 3088f6a7776..8f7ef4ae4c2 100644 --- a/source/blender/editors/transform/transform_mode_translate.c +++ b/source/blender/editors/transform/transform_mode_translate.c @@ -201,8 +201,19 @@ static void headerTranslation(TransInfo *t, const float vec[3], char str[UI_MAX_ } if (t->flag & T_PROP_EDIT_ALL) { - ofs += BLI_snprintf_rlen( - str + ofs, UI_MAX_DRAW_STR - ofs, TIP_(" Proportional size: %.2f"), t->prop_size); + ofs += BLI_strncpy_rlen(str + ofs, TIP_(" Proportional size: "), UI_MAX_DRAW_STR - ofs); + if (unit) { + ofs += BKE_unit_value_as_string(str + ofs, + UI_MAX_DRAW_STR - ofs, + t->prop_size * unit->scale_length, + 4, + B_UNIT_LENGTH, + unit, + false); + } + else { + ofs += BLI_snprintf_rlen(str + ofs, UI_MAX_DRAW_STR - ofs, "%.2f", t->prop_size); + } } if (t->spacetype == SPACE_NODE) { ``` But with this change, we would lose translations of `" Proportional size: %.2f"`. I don't know to what extent such a change justifies losing some translations. --- @mont29, (you know the translations area better), is there any way to get around the problem of losing translations? And is this really a problem?
This issue was referenced by fa1868ae97
This issue was referenced by fa1868ae971c2dc50efb2f5dbf8ed2b2b6f08d08
Germano Cavalcante self-assigned this 2021-06-22 22:18:05 +02:00
Reference: blender/blender#88346
