Experimental Blender builds hard depend on libpulse on Linux #88387
legacy module
legacy module
legacy module
legacy module
Rendering & Cycles
legacy project
3.3
legacy project
legacy project
Documentation
legacy project
Infrastructure: Blender Buildbot
legacy project
Infrastructure: Websites
legacy project
Platform: macOS
legacy project
legacy project
Platform: Windows
legacy project
legacy project
Priority::Low
Priority::Normal
Priority::Unbreak Now!
Status::Archived
Status::Confirmed
Status::Duplicate
Status::Needs Information from Developers
Status::Needs Triage
Status::Resolved
Type::Bug
Type::Report
Type::To Do
Reference: archive/blender-buildbot#88387
Operating system: GENTOO Linux, updated daily
Graphics card: NVIDIA Corporation TU106 High Definition Audio Controller (rev a1)
Graphic driver: x11-drivers/nvidia-drivers-465.31
Broken: blender-3.0.0-alpha+master.d373b43f07f5-linux.x86_64-release
Worked: blender-3.0.0-8057b985727d-linux64
Blender cannot be started without libpulse installed.
Start blender on a system without libpulse being installed.
No blend file needed. Start will instantly aborted. There is even no chance, to disable audio
via commandline switches.
The use of pulseaudio is debatable. User/Sysadmins who decide not to use/install pulseaudio
on their systems will be urged to no longer use Blender anymore.
Suggested solution: Switch back to alsa or make it possible to use wrapper libs like apulse
(https://github.com/i-rinat/apulse).
Last resort: Load libpulse dymanically after processing the commandline switches. This
way, audio can be disabled and libpulse will not be loaded. This way blender will be silenced,
though.
Added subscriber: @mcq
Correction: The Video Card is: NVIDIA Corporation TU106 [GeForce RTX 2060 SUPER] (rev a1)
(I copied the wrong line from lspcis output...sorry)
Added subscribers: @ponderz, @lichtwerk
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
@ponderz : does this ring a bell?
Added subscriber: @scurest
Closed as duplicate of #88431
Added subscriber: @ankitm
