Scale Cage doesn't work well for small/large objects #88579
9 Participants
Reference: blender/blender#88579
Operating system: Win10
Graphics card: GTX2080
Broken: master 2.92 /
02948a2
Using the scale cage to scale an object along an axis does not work properly:
My assumption is, that the hover regions are too large, overlapping, and not sorted correctly with results in unexpected behavior of scaling on two or three axis.
Adding a simple hover effect (2) would drastically improve the situation.
https://youtu.be/ZjJlZb-RuRE
2022-01-30_00-32-30.mp4
Added subscriber: @pixtur
#91517 was marked as duplicate of this issue
#90926 was marked as duplicate of this issue
Added subscriber: @lichtwerk
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
This sounds harsh, your comment about hover regions has a point though and it has come up in #61388 (Custom gizmo created with new_custom_shape are difficul to select.) before.
A little bit of how this works in this comment:
So the situation is not perfect, esp. the hover would really help here, but it is not totally straightforward since atm. all these individual points in the scale cage are not individual
wmGizmo
, the whole thing is one single gizmo.(so you could get a highlite, but only on the whole cage which is obviously not what we are after)
All in all, this does not really sound like a bug to me, more like a request for improved behavior [which this bugtracker is not meant for].
However, I would like a second pair of eyes here if the module wants to keep this as TODO.
Thank you for looking into this in detail!
Regarding the question, if this is a bug, it probably depends ones subjective perspective: For me as a user, if I see a number of clearly seperate selection handles, I expect that precisely dragging one of them just works (I.e. picks the handle below the mouse pointer). In case of the scale cage, scaling on more than one axis will result in unwanted incorrect manipulations that are difficult not notice.
For me this is so annoying that I try to avoid this tool, that is designed for precisely this use case.
Added subscribers: @Vyach, @PratikPB2123
Added subscriber: @michalpe
Hello, I want to say that it IS a bug, and it does need to be fixed. In certain views you literally point your mouse cursor right at the handle and, even though you've got a lot of free space on screen, even though you're zoomed in, so the cage covers nearly all your viewport, even then Blender may pick the wrong handle. It's not just the issue with small objects on screen. The handle sorter is just broken. I hope that the model I attached in the link below will prove it to you, devs.
See my case:
https://developer.blender.org/T91517
Added subscriber: @BulatKR
Scale Cage works mostly stably only with standard primitives - cube and plane etc, but when trying to scale a modeled object, the tool quite often stops working normally.
Poke.
It is still not fixed.
Not only with small objects but with big objects too.
Why this poorly tested tool was implemented in master, but well working vertex paint is not?
Please delete this tool, It do not work in most cases.
It should not to be present in master in that state as it now have
No, don't delete it. FIX it. This tool is crucial for architecture modelling, but it should work properly. Please, prioritize fixing scale cage.
Yes, fix is more desirable, but as far as it do not work, it can`t be in the master
The topic is called "Selecting center handles of Scale Change does not work for small objects", but I would say that this tool simply does not work under any circumstances with more complex objects than a cube.
Selecting center handles of Scale Cage does not work for small objectsto Scale Cage doesn't work well for small/large objectsEven a cube can be problematic, depending on the view angle.
I made a similar topic, but someone made a wrong decision of merging the two topics, while my case presents a different side of this problem - scale cage would pick wrong handle under certain view angles in 3D, regardless of object size:
@michalpe, let`s wait a patch. If there was the same reason, your case will be fixed too,
Otherwise ask to reopen and de-merge under your report.
Added subscriber: @lictex_1
size of the selection area is in world space instead of screen space, this is the real cause of this issue imo
handles on a small object will overlap together, and on a large object it will become so small for clicking
#91517 should be same, hitboxes in that file might look like this
try dragging on the non-overlapping area, or simply scale up the entire object by 10x, it should be able to pick up the correct axis
afaik this tool works on object level and the mesh data underlying shouldn't matter a lot. maybe a .blend file helps showing the problem
I dragged over non-overlapping area, with a simple box. My case can't possibly be simpler, and it still doesn't work properly. If you navigate to my thread:
you'll see an attached .blend.
This issue was referenced by
f7a6e8db04
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
