Mixdown crashes Blender 2.92.0 and 3.0.0 Alpha #88614
Closed
opened 2021-05-27 07:58:24 +02:00 by Karri Rasinmäki · 11 comments
Blender crashes when trying to export a mixdown from Render -> Render Audio...
The problem seems to occur no matter the file format. However, the same feature works on Blender 2.83.15.
The error message Blender gives upon the crash:
terminate called after throwing an instance of 'aud::FileException'
  what():  File couldn't be written, audio encoding failed with ffmpeg.
[1]    3363 abort (core dumped)  blender
And my Blender versions info are:
$ blender --version
Blender 2.92.0
	build date: 2021-04-25
	build time: 11:39:34
	build commit date: 2021-02-24
	build commit time: 16:25
	build hash: 02948a2cab44
	build platform: Linux
	build type: Release
	build c flags:  -Wall -Wcast-align -Werror=implicit-function-declaration -Werror=return-type -Werror=vla -Wstrict-prototypes -Wmissing-prototypes -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wlogical-op -Wundef -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Wformat-signedness -Wrestrict -Wnonnull -Wabsolute-value -Wuninitialized -Wredundant-decls -Wshadow -Wno-error=unused-but-set-variable -Wimplicit-fallthrough=5 -D_FORTIFY_SOURCE=2 -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fuse-ld=gold -fopenmp -std=gnu11 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2
	build c++ flags:  -Wredundant-decls -Wall -Wno-invalid-offsetof -Wno-sign-compare -Wlogical-op -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Werror=return-type -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wundef -Wformat-signedness -Wrestrict -Wuninitialized -Wundef -Wmissing-declarations -Wimplicit-fallthrough=5 -I /usr/include/python3.9 -fuse-ld=gold -fopenmp -std=c++17 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2
	build link flags:  -Wl,--version-script='/build/blender/src/blender/source/creator/blender.map'
	build system: CMake
$ ./blender --version
Blender 3.0.0 Alpha
	build date: 2021-05-27
	build time: 00:38:27
	build commit date: 2021-05-26
	build commit time: 18:32
	build hash: 2c607ec2f6b9
	build type: release
	build c flags:  -Wall -Wcast-align -Werror=implicit-function-declaration -Werror=return-type -Werror=vla -Wstrict-prototypes -Wmissing-prototypes -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wlogical-op -Wundef -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Wformat-signedness -Wrestrict -Wnonnull -Wabsolute-value -Wuninitialized -Wredundant-decls -Wshadow -Wno-error=unused-but-set-variable -Wimplicit-fallthrough=5  -fuse-ld=gold -std=gnu11 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2 -D_GLIBCXX_USE_CXX11_ABI=0
	build c++ flags:  -Wuninitialized -Wredundant-decls -Wall -Wno-invalid-offsetof -Wno-sign-compare -Wlogical-op -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Werror=return-type -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wundef -Wformat-signedness -Wrestrict -Wno-suggest-override -Wuninitialized -Wundef -Wmissing-declarations -Wimplicit-fallthrough=5  -fuse-ld=gold -std=c++17 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2 -D_GLIBCXX_USE_CXX11_ABI=0
	build link flags:  -Wl,--version-script='/home/blender/git/blender-vdev/blender.git/source/creator/blender.map'
	build system: CMake
Blender crashes when trying to export a mixdown from Render -> Render Audio... The problem seems to occur no matter the file format. However, the same feature works on Blender 2.83.15. The error message Blender gives upon the crash: ``` terminate called after throwing an instance of 'aud::FileException' what(): File couldn't be written, audio encoding failed with ffmpeg. [1] 3363 abort (core dumped) blender ``` And my Blender versions info are: ``` $ blender --version Blender 2.92.0 build date: 2021-04-25 build time: 11:39:34 build commit date: 2021-02-24 build commit time: 16:25 build hash: 02948a2cab44 build platform: Linux build type: Release build c flags: -Wall -Wcast-align -Werror=implicit-function-declaration -Werror=return-type -Werror=vla -Wstrict-prototypes -Wmissing-prototypes -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wlogical-op -Wundef -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Wformat-signedness -Wrestrict -Wnonnull -Wabsolute-value -Wuninitialized -Wredundant-decls -Wshadow -Wno-error=unused-but-set-variable -Wimplicit-fallthrough=5 -D_FORTIFY_SOURCE=2 -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fuse-ld=gold -fopenmp -std=gnu11 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2 build c++ flags: -Wredundant-decls -Wall -Wno-invalid-offsetof -Wno-sign-compare -Wlogical-op -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Werror=return-type -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wundef -Wformat-signedness -Wrestrict -Wuninitialized -Wundef -Wmissing-declarations -Wimplicit-fallthrough=5 -I /usr/include/python3.9 -fuse-ld=gold -fopenmp -std=c++17 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2 build link flags: -Wl,--version-script='/build/blender/src/blender/source/creator/blender.map' build system: CMake ``` ``` $ ./blender --version Blender 3.0.0 Alpha build date: 2021-05-27 build time: 00:38:27 build commit date: 2021-05-26 build commit time: 18:32 build hash: 2c607ec2f6b9 build platform: Linux build type: release build c flags: -Wall -Wcast-align -Werror=implicit-function-declaration -Werror=return-type -Werror=vla -Wstrict-prototypes -Wmissing-prototypes -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wlogical-op -Wundef -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Wformat-signedness -Wrestrict -Wnonnull -Wabsolute-value -Wuninitialized -Wredundant-decls -Wshadow -Wno-error=unused-but-set-variable -Wimplicit-fallthrough=5 -fuse-ld=gold -std=gnu11 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2 -D_GLIBCXX_USE_CXX11_ABI=0 build c++ flags: -Wuninitialized -Wredundant-decls -Wall -Wno-invalid-offsetof -Wno-sign-compare -Wlogical-op -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Werror=return-type -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wundef -Wformat-signedness -Wrestrict -Wno-suggest-override -Wuninitialized -Wundef -Wmissing-declarations -Wimplicit-fallthrough=5 -fuse-ld=gold -std=c++17 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2 -D_GLIBCXX_USE_CXX11_ABI=0 build link flags: -Wl,--version-script='/home/blender/git/blender-vdev/blender.git/source/creator/blender.map' build system: CMake ```
Added subscriber: @karrirasinmaki
kathybowing commented 2021-05-27 13:17:44 +02:00 (Migrated from localhost:3001)
Added subscriber: @kathybowing
Added subscribers: @neXyon, @iss
@neXyon Can you reproduce this issue? On Windows things seem to be working fine
Member
Added subscriber: @EAW
Member
I can reproduce with Blender 3.0.0 dfa3dcbab9.
No crash file is written and nothing out of the ordinary shows up in the debug log though, so I'll build a debug build to see if I can get a call stack.
Tested using:
OS: Windows-10-10.0.19041.630-SP0 64 Bits
GPU: GeForce GTX 470/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35
CPU: i7-950 @3.07 GHz SSE2 SSE3 SSE41
RAM: 8.00 GB
blender_system_info.txt
I can reproduce with Blender 3.0.0 dfa3dcbab9. No crash file is written and nothing out of the ordinary shows up in the debug log though, so I'll build a debug build to see if I can get a call stack. --- Tested using: OS: Windows-10-10.0.19041.630-SP0 64 Bits GPU: GeForce GTX 470/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35 CPU: i7-950 @3.07 GHz SSE2 SSE3 SSE41 RAM: 8.00 GB [blender_system_info.txt](https://archive.blender.org/developer/F10145227/blender_system_info.txt)
This issue was referenced by bf8909eb5d
This issue was referenced by bf8909eb5d27b5670b50a3715fe6348dcea449a5
This issue was referenced by 530f2994e9
This issue was referenced by 530f2994e9aeed551ce0cfec7a97a15234ebcb44
Member
Joerg Mueller self-assigned this 2021-05-27 19:06:06 +02:00
Added subscriber: @zhart
Absolutely the same problem.
Blender 2.93.6 on Ubuntu 20.04.
Absolutely the same problem. Blender 2.93.6 on Ubuntu 20.04.
6 Participants
Reference: blender/blender#88614
