Render Queue #88624
5 Participants
Reference: blender/blender#88624
The renderqueue panel is a new panel to organise and plan shots to render.
Why ?
The sampling can be high, to have a good quality, but at cost of render time. When an artist have differents view to render with differents objects shown; it takes a lot of time to render first view, wait for render to finish, then render another view (eventually hide/show some objects, change frame), etc.
In this case, it is useful to have all the renders doing one by one automatically.
The artist rendered at low samples different views, with different compositions. Then, the client want a specific composition. The artist have to manually hide/show the objects to change the composition, change the world...
In this case, it is useful to have a list of overridden settings ( view layer, frame, camera, etc ) to easily recover a view/composition.
Who will need it ?
As described previously, it will benefits to every artists. A huge benefit for artists working with cycles or other path tracing render engine.
A proposed solution
Internally
The data of each shot is stored into a new type structure.
That structure is overriding some scene settings and render settings.
The proposed settings are :
User Experience
The renderqueue list is located in a new panel inside properties editor. It is a list of shots, that have each a different name.
The user can then select some settings to override, and modify them.
The user can then render all the shots automatically or just some.
All the renders are then automatically saved using the shot name.
Pros
This system makes it easy to add new overridable settings, and offer a large choice of possibilities.
Cons
This override system is not easy to do, because of the complexity of view layers(visibility, etc), and require a lot of work.
Alternative solutions
Shot by camera
Each camera can contain overrides of some scene and render settings (sampling, exposure, resolution, viewlayer, etc).
This is a bit simpler on the user side.
This is restrictive, because the user can only define one shot per camera.
Shot by viewlayer
Each viewlayer can contain overrides of some scene and render settings (sampling, exposure, resolution, camera, etc).
This is easier to implement, because all the viewlayer side is already done in blender.
This gives too much viewlayers in the blender file. The user may not want to override the viewlayer.
The strategy for the proposed method
Create a new structure type : RenderQueue.
This structure will first contain two of the elemental elements : the camera and the frame.
Each element has a flag associated, to define if it is used; ex : USE_CUSTOM_FRAME
Each element is shown in its category, in the RenderQueue property panel.
Once this little design is done, we should be able to think about layer overriding.
Mockups
Added subscriber: @Kdaf
Added subscriber: @kathybowing
Added subscriber: @brecht
This is what view layers were designed for. That system should be improved, and get more powerful support for overrides, rather than adding another mechanism.
The name is also confusing, since in some other 3d apps the "render queue" is a job scheduling system.
Overall, I think this design is not the right direction.
Alright, no problem, have you got any idea of how a Render/Shot Queue could work ?
I mean, you said viewlayers are made for this. But we cant even change camera by view layer. Is it in this direction that it could go ?
Making a kind of Shot by viewlayer as I mentionned ?
Ideally view layers would support a more generic override mechanism, where any scene property can be overridden. But that is rather complicated to implement well.
Adding a few more options to the Overrides panel would be a good step. Currently that only has material and samples, adding a camera override there would make sense.
Do you think I could make that ( adding camera override ) ? Or is it part of a larger change ?
Removed subscriber: @kathybowing
You could implement that yes.
Added subscriber: @juang3d
Regarding this @brecht I think there are two perspectives here:
The Per Camera one: that's a good one, because we often need to render several cameras in a scene, imagine a pack shot, or having to render several static cameras of different places in a set, or having a bunch of detail renders of a character, right now there are rudimentary ways to do that, but a camera queue would allow us to avoid all this.
The View Layer perspective: that one would make useless the view layers as a scene separation element, so I kind of agree that this sould not be used in this way.
With that said there is a point regarding the Per Camera idea:
While ViewLayers are defined to be able to generate overrides in the scene, there are scenes with several ViewLayers that have to be rendered from different cameras with different resolutions, picture this structure for example:
All that will be used inside the compositor to assemble the final beauty image.
Now if we need to render a collection of static pictures of that situation we have the two approaches here:
Per Camera: we have the camera lists, each camera will render it's own sets of view layers, the only main override a camera would need would be the resolution, because you often need to render different sizes, vertical/horizontal, with different proportions, etc...
However a samples override per camera could come handy, but if it's too out of scope can be totally discarded
Per ViewLayer: in this situation the queue would be useless, because the previews compositing view layer setup would render useless, it could generate a ton of view layers but we won't be able to use our composite configuration or we will be forced to configure one specific compositing tree per camera, which is a problem too and not efficient at all.
So IMHO the Per Camera approach is the best one, I agree with keeping it as simple as possible, so it can be just a camera queue with a resolution setting per camera, nothing less nothing more.
But the Per ViewLayer approach would make View Layers useless if they have to be used with the compositor or with a scene with several view layers.
Regarding the overrides, this could be a different proposal with a different design that later could be combined with ViewLayers and/or with the Camera Queue :)
Added subscriber: @Dae_mmm
layer manager might be the way to handle what he described, but render queue has a different meaning:
with a render queue you can decide to render:
from frame 1 to frame 100
from frame 300 to frame 500
Have a still of frame 1 in 4k
Have a still of frame 300 in 4k
Have from frame 100 to 700 of file "LoremIpsum.blend"
Have a still of frame 150 of file "LoremIpsum.blend"
After setting all up you can click on "start queue" and have everything later
