driver late update after Alt+G for leading object #88689
Reference: blender/blender#88689
Operating system: Windows-8.1-6.3.9600-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.47
Broken: 2.83.9 and later ( 2.93.0 Beta, branch: master, commit date: 2021-05-28 16:16, hash:
c369382977
)Short description of error
when I press Alt-G drivered value updates, but actual scale don`t
Here the file and demo
drv late.blend
2021-05-30_20-44-24.mp4
Added subscriber: @Vyach
Added subscriber: @lichtwerk
Can confirm.
Right now, one driver is dependent on the height and sets the X-Scale, the second driver takes the computed X-Scale and sets the Y-Scale.
You can get it to update one step futher if you make both X and Y scale take the height as input for the scripted expression.
One dimension is then updated properly in the viewport and both values are updated properly in the sidebar UI.
Still, this is unexpected behavior, cancelling a transform on the other hand does a better job here.
@lichtwerk
Yep, I had made this approach too. With same result.
And it still requires double {key Alt+G} press. So something prevents proper chain reaction.
Unfortunately, this isn't a bug per se, but rather a limitation of Blender's current dependency graph:
Blender sees this as a dependency cycle. Of course, practically there is no dependency cycle, but the dependency graph doesn't have a granular enough view of transform properties to distinguish e.g. the different scale channels as unique entities.
If you start Blender from the command line and open the test file, you immediately get the following output:
Additionally, the delay is actually happening all the time. When dragging the controller interactively, the update rate makes it not obvious. But if you animate the controller moving significantly over just a couple of frames, then frame stepping also reveals the same delay. This is classic dependency cycle behavior.
So although this is certainly undesirable behavior, it's unfortunately not a bug. Just a (known) limitation of Blender at the moment.
