Face instancing giving unexpected behaviour in combination with the mirror modifier and various deform modifiers #88708
2 Participants
Reference: blender/blender#88708
Operating system:
Win10
Graphics card:
Broken: 3.0.0 Alpha
Worked: -
Mirroring & using deform modifiers result in unpredictable results when using "face instancing".
As you can see in the screenshot, the "instanced" geometry (the children of the object using face instancing) wont mirror accordingly. Similar issues appear when using many of the deform modifiers,
Expected behaviour
Face instancing should be able to use in combination with modifiers, and the results should display appropriately.
Create a new blend file, add a plane & enable face instancing, parent the default cube under it and move it so you can see the plane & cube separately.
Now add another mesh, move it to a location of choice & add a mirror modifier to our face instance plane & set the mirror object to this new mesh.
Rotate the default cube by some odd value, say 25 degrees on every angle and apply the rotation.
Now you should be able to clearly see how the cube doesnt mirror properly when instanced with the face instancing.
This can also be reproduced with most deform modifiers.
If you apply the modifiers of our face instanced plane, enable Viewport > Edit mode > Overlays > Developer > Indices you will see something like this:
and from here we can make a guess that likely, the face instancing algorithm uses face instances to determine the rotation of the face. Which gets broken by the mirror modifier (and several deform modifiers).
Added subscriber: @Olliver
Seems there is an abandoned branch for this already: https://developer.blender.org/D8445
Added subscriber: @lichtwerk
I think this is actually to be considered as a Known Limitation
https://docs.blender.org/manual/en/dev/scene_layout/object/properties/instancing/faces.html#limitations-considerations
But yeah, since we already have #77575 (collection instance rotates 90 degrees automatically when being instantiated by another object with mirror modifier) I think it makes sense to merge these reports.
And using geometry nodes might get the recommended way of doing this (even though the face method is a lot quicker to set up)
Closed as duplicate of #77575
