Sign Flipping on Ctrl+R #88741
2 Participants
Reference: blender/blender#88741
Graphics card: GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.81
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
You can duplicate this bug in any file. Add a polygon - anything will do; I use a circle or a plane to duplicate the bug. Enter edit mode. Select all vertices. E for extrude. R for rotate. X, Y, or Z to pick an axis. Enter a degree count (I use 2). So add a polygon, edit mode, select all, E, R, X, 2. Do this once. Then do shift+r to duplicate last command. The rotate amount flips its sign. Using the settings I just mentioned, the first time I rotate "manually" it will rotate 2 degrees. Ctrl+R then rotates it -2 and it continues rotating -2 with every Ctrl+R. IF YOU DON'T SPECIFY AN AXIS, THE BUG DOES NOT OCCUR. The degree count does not flip the sign unless an axis is specified in the rotation amount. This should be an EZPZ fix.
Added subscriber: @CMalcheski
Added subscriber: @lichtwerk
Could confirm in 2.92, but this seems fixed already.
Please try a fresh build from https://builder.blender.org/download/daily/.
Will close as resolved, but feel free to comment again if issues persist in a fresh buildbot build (we can always reopen in such case)
