Vertices have negative indices after leaving edit-mode #88826
2 Participants
Reference: blender/blender#88826
Operating system: Windows 10
Graphics card: NVidia GeForce GTX 1650
Broken: 2.83, 2.92
Worked: -
When storing references to vertices, that have been created using a modifier, their indices are negative some times.
A
blend
-file is attached.Given is a chain of edges. These edges are extruded in one direction and then solidified using a Solidify-Modifier. In the end a loop cut will be inserted. References to the vertices, selected by the new loop cut, will be stored in a list. After leaving edit mode and entering it again, the vertices may have negative indices and can't be selected using
bpy.context.active_object.data.vertices[storedVertex.index]
. However, this problem occurs not every time, but at around 3-5 out of 10 tries.To reproduce the error, run the script and revert the file if no error has occured.test.blend
Added subscriber: @Kruspe
Vertices have negative indices when toggling edit-modeto Vertices have negative indices when after leaving edit-modeVertices have negative indices when after leaving edit-modeto Vertices have negative indices after leaving edit-modeAdded subscriber: @lichtwerk
I think you might be running into these:
Do you agree this might be the reason?
Think you could avoid this by not storing references?
@lichtwerk Alright. You're correct. I now stored the vertices in actual vertex groups that let me retrieve them.
Changed status from 'Needs User Info' to: 'Resolved'
Sounds like a valid solution (I havent looked in depth).
So will close then, thx getting back.
