Audio causes issues with Playback when PC put to Sleep, Hibernate or when Screensaver appears
Closed, ResolvedPublicBUG
Operating system: Windows 10
Graphics card: RTX 2080
Broken: 2.93.1 Release Candidate, 7edbe463d2d9 and 2.93 Stable Release
Worked: 2.92 Stable Release
When added Audio in Video Editor tab and Playback set to 'Sync to Audio', when PC is put to Hibernate, Sleep or just left for Screensaver to appear, after waking PC up the animation does not play, only moves one frame and then stops. With Playback set to 'Frame Dropping' it does play, only without sound.
After checking other bug reports I can confirm that changing Audio Device from WASAPI (which is now a default in 2.93) to OpenAL in Preferences -> System -> Sound does fix the issue, so the problem seems to be newly added device.
-Start a new 2.93 project with default user preferences
-Add audio file in Video Editing tab
-Set Playback in Timeline tab to 'Sync to Audio'
-Leave PC for a while to Screensaver to appear or force Hibernate/Sleep mode
-Return to the project and enjoy not being able to play the animation :)
Marking this as a duplicate of T88879: Choppy audio. Still it's hard to tell.
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Jun 7 2021, 7:56 AM
I can reproduce this issue with wasapi, so I can help debug this if needed. I have found that switching Audio Device to None and back to WASAPI will fix this issue.
@Joerg Mueller (nexyon) are you aware of this issue?
Joerg Mueller (nexyon) changed the subtype of this task from "Report" to "Bug".
I'll look into it!
@Richard Antalik (ISS) can you try if this patch fixes the issue?
Seems to work fine
