Erro in get_type_hints when registering text as module (bug in Python, fix pending) #88986
6 Participants
Reference: blender/blender#88986
Graphics card: Intel(R) Iris(R) Plus Graphics Intel 4.5.0 - Build 27.20.100.8681
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash:
84da05a8b8
Worked: 2.92
When using the
as_module
function on a script and runningregister
blender throws an error:Exact steps for others to reproduce the error
example.blend
Run the two commands specified in the text file to get the module and register it. I modified the Simple Operator template to make it as simple as possible.
This worked for me in 2.92 for registering and unregistering generated addons dynamically. While it still seems to register in 2.93 operators throw this error. They do appear to be registered when you use them in buttons for example but the property ('test' in the example file) isn't found.
Added subscriber: @JoshuaKnauber
#89325 was marked as duplicate of this issue
Added subscriber: @WCN
This may have been fixed upstream:
https://bugs.python.org/issue41515
For the other users in this thread:
I think I've managed to patch this issue out of my Blender, by going to
2.93/python/lib/python3.9/typing.py
in my Blender install directory and changing the one line below.Change line 1408 from:
base_globals = sys.modules[base.__module__].__dict__
to
base_globals = getattr(sys.modules.get(base.__module__, None), '__dict__', {})
This doesn't seem to have any side effects, and I don't think it really should have any side effects, as it should only modify the code path in conditions where it would otherwise result in an error.
On Blender source code itself:
I think passing an empty dictionary for
globalsn
totyping.get_type_hints(cls, globalsn={})
in Blender may be enough to get the previous behaviour:https://docs.python.org/release/3.9.5/whatsnew/changelog.html#id272
It seems to work for getting annotations from the class in the console panel, anyway.
I'm not sure the change upstream is actually going to fix this either. It looks like the new default behaviour is that classes defined in a synthetic module will just be skipped, and not have their annotations collected at all:
https://github.com/python/cpython/pull/25352/files#diff-ddb987fca5f5df0c9a2f5521ed687919d70bb3d64eaeb8021f98833a2a716887
So it may be necessary to pass an empty
dict
forglobalsn
even after the upstream fix.Found the commit where the change was introduced:
f350a268a7 (diff-ddb987fca5f5df0c9a2f5521ed687919d70bb3d64eaeb8021f98833a2a716887R1501)
I opened an issue upstream, for the Python standard library:
https://bugs.python.org/issue44468
If they decide to make the new change suggested, then I think that should also fix this issue.
Maybe it'd still be better to explicitly pass an empty
dict
though, to avoid relying on opaque behaviour.Erro in get_type_hints when registering text as moduleto Erro in get_type_hints when registering text as module (bug in Python, fix pending)I submitted a fix upstream, which has now been merged:
https://github.com/python/cpython/pull/26862
It's been backported to the 3.10 branch, so I guess it will make it into the next release.
Still in Python 3.9.6. There doesn't seem to be any backport for version numbers below 3.10.
Just curious: What is the first version of Blender planned to ship with Python 3.10? (Until then I will have to manually patch the static program files.)
Is there any update on this? I guess this is fixed with python 3.10 to get back to Will's question of when this version will be in blender?
Added subscriber: @ispaure
Hi, I also need this for my code (and have needed to patch the program files since this summer (typing.py) to fix this). Would appreciate any update on when it will be implemented or how to fix my current issue.
def import_python_module_absolute_path(path):
I am thinking my function here is the culprit, but unsure how I need to change it to bypass this issue. Any help very much appreciated. Thanks :)
Additional note: It's when I try to register this created class with bpy.utils.register_class(foo) that I get the error, which didn't happen before Blender switched python version sometime in late 2020 or early 2021.
@ispaure The SVN files for Blender 3.1 have a patched Python 3.10 version in them, so hopefully that will bring the fix to more users.
https://svn.blender.org/svnroot/bf-blender/tags/blender-3.1-release/lib/win64_vc15/python/
https://svn.blender.org/svnroot/bf-blender/tags/blender-3.1-release/lib/win64_vc15/python/310/lib/typing.py
IIRC the problem is a result of synthetic modules: When a module is constructed from a string, file, or some such instead of the usual import mechanisms, the classes in it don't have a
.__module__
attribute valid forsys.modules- [ ]
, so Python 3.9 skips evaluating their type hints for subclasses.I suppose if you want to "fix" that function, you would probably look into filling in
.__module__
in the classes andsys.modules
with a synthetic module name:E.G.:
Not sure if this the above will be enough. It's been a while since I've looked at this.
Personally I haven't run into this issue since 3.0, though I think that's because my OS's Blender package links to system Python3.10.
Added subscriber: @ideasman42
This is no longer a problem for Python 3.10 & Blender 3.1, closing.
