Cycles renders only two frames of animation #89040
Closed
opened 2021-06-10 23:09:59 +02:00 by Nikita · 10 comments
Graphics card: GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 462.59
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: 84da05a8b8
Worked:
Cycles render only two frames of animation when all of these functions are enabled: Time remapping (with ratio more than 1), Motion Blur and Persistent Data.
To recreate this problem you need to create animation, set time remapping with ratio more than 1 (for example 60/24), enable Motion blur and enable Persistent data, as you can see in attached file.
untitled.blend
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 462.59 **Blender Version** Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: `84da05a8b8` Worked: **Short description of error** Cycles render only two frames of animation when all of these functions are enabled: Time remapping (with ratio more than 1), Motion Blur and Persistent Data. **Exact steps for others to reproduce the error** To recreate this problem you need to create animation, set time remapping with ratio more than 1 (for example 60/24), enable Motion blur and enable Persistent data, as you can see in attached file. [untitled.blend](https://archive.blender.org/developer/F10166288/untitled.blend)
Author
Added subscriber: @Kozn
Added subscriber: @Zandman
Confirmed with attached Blend file on macOS Big Sur on MacBook M1. When I manually created a new animation based on the instructions the rendering stopped at frame 5. So the position where rendering stops seems to vary.
Maybe related to #89053, as that issue also claims to be Motion Blur + Persistent Data related.
Confirmed with attached Blend file on macOS Big Sur on MacBook M1. When I manually created a new animation based on the instructions the rendering stopped at frame 5. So the position where rendering stops seems to vary. Maybe related to #89053, as that issue also claims to be Motion Blur + Persistent Data related.
Member
Added subscriber: @Alaska
Member
Member
I can confirm this issue with Blender 2.93 release and Blender 3.0 on Linux (see information below).
I decided to bisect the issue and to see if any more information could be found out. The "culprit" commit is the introduction of Persistent Data. 50782df425
I also ran Blender with the commend --debug-all and I couldn't find anything useful from it.
Operating system: Linux-5.10.0-7-amd64-x86_64-with-glibc2.31 64 Bits
Blender Version: 3.0.0 Alpha, branch: master, commit date: 2021-06-11 21:39, hash: d75e45d10c
I can confirm this issue with Blender 2.93 release and Blender 3.0 on Linux (see information below). I decided to bisect the issue and to see if any more information could be found out. The "culprit" commit is the introduction of `Persistent Data`. 50782df425 I also ran Blender with the commend `--debug-all` and I couldn't find anything useful from it. **System Information** Operating system: Linux-5.10.0-7-amd64-x86_64-with-glibc2.31 64 Bits **Blender Version:** 3.0.0 Alpha, branch: master, commit date: 2021-06-11 21:39, hash: `d75e45d10c`
There seems to have been some prior problems with Motion Blur and Persistent Data: #87283, though that is marked as being fixed.
Member
This issue is different as it's the time remapping along with motion blur and persistent data that is causing the issue from the looks of it.
This issue was referenced by a072e87e04
This issue was referenced by a072e87e04ee583f899db4bd174e1804c97b3c9d
Brecht Van Lommel self-assigned this 2021-07-12 17:43:12 +02:00
5 Participants
Reference: blender/blender#89040
