Archimesh add-on creation menu can not be found #89280
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#89280
Operating system:windows 10
Graphics card:GTX 1070
Broken:2.93
(example: 2.79b release)
when i enable archimesh in the addons menu it doesn't show up and i cant use it anywhere it says it can be used from
Added subscriber: @Cameron2462
Added subscriber: @Alaska
In the add-ons tab for
Archimesh
I see this:It says I can find the menu to create
Archimesh
objects in theView3D > Add Mesh/Sidebar > Create tab
and I can createArchimesh
objects from those locations?Are you able to better describe your issue so we can identify if this is a bug? It may be that the location description can be confusing and it needs to be updated.
Here's where the menus being described by the add-on can be found:
archimeshto Archimesh add-on creation menu can not be foundChanged status from 'Needs User Info' to: 'Archived'
