Different Render Results Between CPU and GPU #89351
Closed
opened 2021-06-22 06:47:42 +02:00 by Rick · 17 comments
Graphics card: NVIDIA GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.77
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: 84da05a8b8
I've noticed when rendering an ocean scene in cycles, using optix with 1 GPU and a CPU, I get little discolored squares all around the visible portions of the ocean, and the only way to prevent that from happening is to render on either my CPU or GPU alone, switch to a different render device, or just make sure that the ocean isn't visible in the render. Upon writing out this letter, I've also noticed that Optix seems to produce an odd shadow across the object that Cuda does not produce. This shadow also vanishes when rendered in Optix with only my CPU. My graphics card drivers are up to date, and I also tried restarting my PC, but it didn't change anything. I can render with CUDA instead, it's not a problem, but figured I should report the bug anyway.
Render the attached .blend file, with optix as the selected render device, using a single GPU and CPU.Bug Sample blend file.blend Optix CPU and GPU.png
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.77 **Blender Version** Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: `84da05a8b8` Worked: (newest version of Blender that worked as expected) **Short description of error** I've noticed when rendering an ocean scene in cycles, using optix with 1 GPU and a CPU, I get little discolored squares all around the visible portions of the ocean, and the only way to prevent that from happening is to render on either my CPU or GPU alone, switch to a different render device, or just make sure that the ocean isn't visible in the render. Upon writing out this letter, I've also noticed that Optix seems to produce an odd shadow across the object that Cuda does not produce. This shadow also vanishes when rendered in Optix with only my CPU. My graphics card drivers are up to date, and I also tried restarting my PC, but it didn't change anything. I can render with CUDA instead, it's not a problem, but figured I should report the bug anyway. **Exact steps for others to reproduce the error** Render the attached .blend file, with optix as the selected render device, using a single GPU and CPU.[Bug Sample blend file.blend](https://archive.blender.org/developer/F10187380/Bug_Sample_blend_file.blend) ![Optix CPU and GPU.png](https://archive.blender.org/developer/F10187423/Optix_CPU_and_GPU.png) ![Cuda CPU and GPU.png](https://archive.blender.org/developer/F10187424/Cuda_CPU_and_GPU.png) ![Optix CPU only.png](https://archive.blender.org/developer/F10187425/Optix_CPU_only.png) ![Optix GPU only.png](https://archive.blender.org/developer/F10187426/Optix_GPU_only.png)
Author
Added subscriber: @Arcomade
#91570 was marked as duplicate of this issue
Added subscriber: @Zandman
Isn't it perfectly normal to get different results between rendering on CPU and GPU? They use different algorithms. In general GPU is faster, but CPU supports more rendering features and produces better results. I think I read somewhere that when you want consistent rendering results, you have to either render on GPU or CPU, but not mix both.
Now, there could definitely still be a bug here. Just wanted to add my two cents.
Isn't it perfectly normal to get different results between rendering on CPU and GPU? They use different algorithms. In general GPU is faster, but CPU supports more rendering features and produces better results. I think I read somewhere that when you want consistent rendering results, you have to either render on GPU or CPU, but not mix both. Now, there could definitely still be a bug here. Just wanted to add my two cents.
Member
Added subscriber: @Blendify
Member
@Zandman CPU and GPU should give the same results.
Google says otherwise:
But since this isn’t a discussion forum and it’s not my expertise, I don’t have anything more to add here :-)
> In #89351#1181105, @Blendify wrote: > @Zandman CPU and GPU should give the same results. Google says otherwise: * https://www.reddit.com/r/Amd/comments/65h4py/eli5_why_is_gpu_rendering_lower_quality_than_cpu/ * https://renderpool.net/blog/cpu-vs-gpu-rendering/ * https://blog.cherryservers.com/cpu-or-gpu-rendering-which-is-better-one But since this isn’t a discussion forum and it’s not my expertise, I don’t have anything more to add here :-)
Closed as duplicate of #85078
What makes you think this is a duplicate of #85078? This issue is about mixing CPU and GPU, right. The other one is just using one variant.
Member
Added subscriber: @Alaska
Member
Changed status from 'Duplicate' to: 'Needs Triage'
Alaska reopened this issue 2021-09-18 08:48:34 +02:00
Member
The reason why these reports were probably merged is because the report is talking about a issue with the GPU rendering differently from the CPU. In this specific case, that OptiX is rendering differently from the CPU.
#85078 (OptiX GPU rendering artifacts with large plane) is a bug report for the issue that's causing OptiX to render differently from the CPU in this case. So once #85078 (OptiX GPU rendering artifacts with large plane) is fixed then this specific bug report will also be fixed.
> In #89351#1182663, @Zandman wrote: > What makes you think this is a duplicate of #85078? This issue is about mixing CPU and GPU, right. The other one is just using one variant. The reason why these reports were probably merged is because the report is talking about a issue with the GPU rendering differently from the CPU. In this specific case, that OptiX is rendering differently from the CPU. #85078 (OptiX GPU rendering artifacts with large plane) is a bug report for the issue that's causing OptiX to render differently from the CPU in this case. So once #85078 (OptiX GPU rendering artifacts with large plane) is fixed then this specific bug report will also be fixed.
Added subscriber: @brecht
If the underlying issue is the same, reports should be merged.
Added subscribers: @PabloCio, @ThomasDinges, @PeterBaintner
7 Participants
Reference: blender/blender#89351
