Installing add ons from desktop library #89447
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#89447
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
Added subscriber: @MrN0AHh
When I am installing add on of Spread objects, or any other add on from the desktop library, it completes the installation but doesn't show up on the add on library in the prefrences menu.
Added subscriber: @rjg
Thank you for your report. Unfortunately, it does not contain the requested information that we need to investigate the issue. Please read this guide , it may help you write a bug report that allows us to identify the cause of the problem.
If you need help learning or using Blender, please post a question on one of our [community websites ]], for instance https:*blender.stackexchange.com/ , https:*blenderartists.org/ or the [ https:*blender.chat/channel/support | #support channel on Blender chat . The bug tracker is only for bug reports.
In case you believe that you've found a bug, please create a new bug report through Help > Report a Bug in Blender. We expect all bug reports to follow the submission template . Please provide system information (operating system, GPU, graphics driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and a link where the add-on is available.
Please make sure to install the add-on through the preferences (Edit > Preferences > Add-ons > Install). A common mistake for projects hosted on GitHub is to just download the repository as ZIP. However, some repositories aren't structured to have the
__init__.py
in the top most directory, thus attempting to install it will result in a non-functional add-on. Those repositories will most likely offer a properly packaged add-on in the release section of the repository.For more detailed instructions see this answer on Blender's Stack Exchange.
