Object using Point Instance GN node can not be converted to mesh. #89472
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
5 Participants
Reference: blender/blender-manual#89472
Graphics card: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.27
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-06-25 20:57, hash:
blender/blender@5759bbe9f9
When using GN for procedural modeling and utilizing the Point Instance node, the result can not be converted to a mesh.
Before:
After:
Any geometry generated by the Point Instance node simply disappears
Result: Geometry generated with Point Instance node disappears upon mesh conversion
Expected: The entire visible procedurally modeled mesh, as is, becomes actual new mesh datablock
Added subscriber: @Rawalanche
blender/blender#91324 was marked as duplicate of this issue
Added subscribers: @HooglyBoogly, @lichtwerk
Afaict, this still holds true (and is the only way to get instances as real geometry.
Will double-check with geonodes team
Running the geometry through an
Attribute Fill
node will also makeConvert
orApply
work.Changed status from 'Needs Triage' to: 'Confirmed'
Talked to @JacquesLucke and this needs documentation
Yes, but it will also cause this bug: https://developer.blender.org/T89470
So I have a choice between:
A, Not getting a tree crown I can export to a game engine
B, Getting a tree crown but without UVs so I can not export it to a game engine
The main problem here is that make instances real operator workflow is abysmal:
This is just way too many tedious and error prone steps when someone just wants to turn the result of their GN procedural modeling workflow into an actual mesh.
@Rawalanche: I hear you.
Yes, I assume it would be best to fix blender/blender#85962 (Many Nodes (Join geometry, Boolean, Object Info?) and realizing instances remove UVs (output float2, not MLoopUV).) and make it clear why running this through an Attribute Fill is neccessary.
Using "Make Instances Real" is just the "workaround" in this scenario (and I also understand why this is suboptimal).
Added subscriber: @Astronet-4
Since we have a realize instances node now, this report doesn't apply. The design has changed a fair amount, now we don't try to hide instancing and realize data implicitly. For the issue with UVs, we already have the other report that @licktwerk mentioned, so I'll close this task.
