Can't remove keyframes without active keying set #89592
Reference: blender/blender#89592
Graphics card: NVIDIA GeForce GTX 1650 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.11
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-06-26 21:49, hash:
7223a0348f
Worked: 2.93.0 Alpha, branch: master, commit date: 2021-04-09 21:26, hash:
0515ff70ec
Caused by
7fc220517f
Pressing Alt+I, to delete keyframes, returns a Report:
Error: No active Keying Set
The original operator
bpy.ops.anim.keyframe_delete_v3d
was replaced withbpy.ops.anim.keyframe_delete
This operator doesn't ask for confirmation to delete a keyframe and instead uses the active Keying Set.
However, if no keying set is active in the scene, or specified in the operator's call, then it returns this error.
The operator's Keying Set defaults to
'DEFAULT'
, which uses the scene's active keying set but there's no fallback to the standard actual default'LocRotScale'
Added subscriber: @Phigon
Can confirm. I will bisect to find the culprit.
Caused by
7fc220517f
(Checking if behavior is intended)
This comment was removed by @PratikPB2123
Changed status from 'Confirmed' to: 'Needs Developer To Reproduce'
Added subscriber: @dr.sybren
After reading discussion from #88068 I think this is really not a bug. Behavior has changed after the commit
7fc220517f
.So far All keyframes were supposed to delete from active frame after pressing
Alt + I
Story after the mentioned commit:
Alt + I
deletes keyframes of active keying set.Hi @dr.sybren , if you think this is not a bug/issue then can I/you close the task?
May be manual needs as update to describe the change.
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
Since {key I} works without keying set, I think it's fair that {key Alt I} should also work without keying set. The old behaviour (of
) also worked without keying set, so yes, I do see this as a regression bug.While making myself a workaround/patch (python) for this, I decided to add this as a keyingset menu, like {key I} does, since the original default was just a single confirmation for LocRotScale.
So, request: An optional menu, to function the same as Insert Keyframes.
@dr.sybren , thanks for confirming.
From triaging policy I assume this report should be marked as High priority because of recent regression. Since you are the Module owner I leave this decision for you :)
This issue was referenced by
1364f1e35c
I didn't want to think about task priorities, so I just fixed the issue instead ;-)
