EEVEE AO Shader ignores scene AO settings #89694
Reference: blender/blender#89694
Operating system: macOS-11.4-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 5500M OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.5.14
Broken: version: 2.93.1, branch: master, commit date: 2021-06-22 05:57, hash:
1b8d33b18c
Worked: 2.92
open the attached blend file. use a higher factor (i.e. 3.0) for AO in main settings. The shader will ignore the factor.
making the same steps in 2.92 will produce a multiplied AO in the shader
AO_shader_293.blend
Added subscriber: @icappiello
Added subscribers: @Jeroen-Bakker, @fclem
AO Shader ignores scene AO settingsto EEVEE AO Shader ignores scene AO settingsAdded subscriber: @user1
Can't confirm on Linux
@user1
please add some specific detail about OS, Machine, and blender version.
Just tested on Linux UBUNTU 18.04.4 LTS + GEForce GTX570 + Blender 2.93.1, and the issue is present.
Also, don't play with distance setting in the AO shader. Just open the same file in both 2.92 and 2.93 and compare results.
Operating system: Linux-5.4.0-77-generic-x86_64-with-glibc2.27 64 Bits
Graphics card: GeForce GT 630/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.143
3.0.0 Alpha, branch: master, commit date: 2021-07-05 22:24, hash:
4eeec6e9b5
@user1 Then you are not testing correct blender version. Should be 2.93.1 you are instead testing on Blender 3.0 Alpha.
edit:
i also double checked using 3.0alpha and the issue is present there too.
Added subscriber: @AdrianoDElia
confirm on linux too.
Operating system: Linux-5.4.0-74-generic-x86_64-with-glibc2.27 64 Bits
Graphics card: GeForce GTX 570/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.143
1b8d33b18c
Can't confirm with 2.93.1 (on same system as above):
unfortunately can confirm the issue on 3.0alpha too
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-07-06 23:09, hash:
6ac3a10619
@user1
Please follow instructions. Download the blend file and use it. Seems quite clear to me you are not testing the same blend file moreover the plane has a different material (and so obviously reacting to the general AO instead of using the shader). If you look at the monkeys they have a completely different AO ignoring the settings you cranked up in the main settings, and respecting what you manually set in the shader (which you should not touch btw).
If you want to help please follow the attached instruction to reproduce:
Sorry for the unconvenience. You're right - with the given file i can reproduce the issue.
Added subscriber: @brecht
I think the 2.93 behavior is correct, and consistent with Cycles as well. The AO node is mainly intended for texturing, not lighting. For example to add wear on corners. For such cases the texture should not be affected by the scene lighting settings.
@brecht thanks for the clarification.
Unfortunately this affect badly toon shaders created in 2.92 and ported to 2.93. But as long as this is not going to change again, i am ok with fixing the toon shaders AO inside the node.
