Retrieving evaluated mesh when realizing geometry nodes instances can fail #89905
Closed
opened 2021-07-16 19:55:18 +02:00 by Simon Thommes · 10 comments
Member
Operating system: Linux-5.11.0-7614-generic-x86_64-with-glibc2.32 64 Bits
Graphics card: Quadro RTX 6000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.73.01
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-07-16 07:47, hash: 038345fa56
Worked: Caused by {bfa3dc91b75407b063f2ac991b176d98c050f92d}
When realizing many instances from a collection info node, often many instances will fail to appear. It happens more often when there are more instances, and it depends on threading.
vertex_groups_evaluation_bug.mp4
vertex_group_evaluation_failure.blend
Open sample file, enable viewport visibility of Plane object. Repeat.
Simpler example:
Toggle visibility for the "Points" object. Repeat until only some instances appear.
#89905 Reproduce.blend
**System Information** Operating system: Linux-5.11.0-7614-generic-x86_64-with-glibc2.32 64 Bits Graphics card: Quadro RTX 6000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.73.01 **Blender Version** Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-07-16 07:47, hash: `038345fa56` Worked: Caused by {bfa3dc91b75407b063f2ac991b176d98c050f92d} **Short description of error** When realizing many instances from a collection info node, often many instances will fail to appear. It happens more often when there are more instances, and it depends on threading. [vertex_groups_evaluation_bug.mp4](https://archive.blender.org/developer/F10226050/vertex_groups_evaluation_bug.mp4) [vertex_group_evaluation_failure.blend](https://archive.blender.org/developer/F10226054/vertex_group_evaluation_failure.blend) **Exact steps for others to reproduce the error** Open sample file, enable viewport visibility of `Plane` object. Repeat. Simpler example: Toggle visibility for the "Points" object. Repeat until only some instances appear. [#89905 Reproduce.blend](https://archive.blender.org/developer/F10226249/T89905_Reproduce.blend)
Author
Member
Added subscriber: @SimonThommes
Member
Hans Goudey self-assigned this 2021-07-16 20:35:12 +02:00
Member
I've done a bit of investigation here. The problem seems to be a bit bigger than just the vertex groups, and I can also replicate it by realizing the instances before distribution.
Sometimes the mesh generated from joining the instances is smaller than other times:
New mesh size: 34680
New mesh size: 30923
New mesh size: 31790
New mesh size: 26010
It doesn't happen in a build without TBB (no threading).
This is quite odd, I'm not sure how the vertex refactor would cause this! I'll continue investigating later today.
I've done a bit of investigation here. The problem seems to be a bit bigger than just the vertex groups, and I can also replicate it by realizing the instances before distribution. Sometimes the mesh generated from joining the instances is smaller than other times: ![image.png](https://archive.blender.org/developer/F10226103/image.png) ``` New mesh size: 34680 New mesh size: 30923 New mesh size: 31790 New mesh size: 26010 ``` It doesn't happen in a build without TBB (no threading). This is quite odd, I'm not sure how the vertex refactor would cause this! I'll continue investigating later today.
Member
Further investigation reveals that BKE_modifier_get_evaluated_mesh_from_evaluated_object sometimes returns NULL when gathering instances meshes to be realized.
I think I will bisect this just to make sure it's actually caused by the vertex group refactor.
Further investigation reveals that `BKE_modifier_get_evaluated_mesh_from_evaluated_object` sometimes returns NULL when gathering instances meshes to be realized. I think I will bisect this just to make sure it's actually caused by the vertex group refactor.
Member
Bisecting finished, and it points to bfa3dc91b7
Honestly that makes a lot more sense based on the behavior I was observing when meshes are collected for instancing.
Bisecting finished, and it points to bfa3dc91b7 Honestly that makes a lot more sense based on the behavior I was observing when meshes are collected for instancing.
Hans Goudey changed title from Vertex group evaluation failing on realized instances in geometry nodes to Retrieving evaluated mesh when realizing geometry nodes instances can fail 2021-07-17 03:43:34 +02:00
Hans Goudey removed their assignment 2021-07-17 03:43:48 +02:00
Member
Member
Added subscriber: @mano-wii
Member
Maybe @mano-wii has an idea of the cause here?
Member
Hans Goudey self-assigned this 2021-07-19 15:22:43 +02:00
Member
Solved by ceb612a79c
2 Participants
Reference: blender/blender#89905
